Old 05-27-2014, 06:50 PM
Ron, Where does the C5/C6/Z06 Etc. sealed bearing assembly fit into this equation? The GM guys have the luxury of going with a ATS spindle that utilizes a c6 bearing pack. I know mine were still tight when I sold my car. Not that much road racing time, however.
Old 05-28-2014, 12:10 PM
Ron Sutton's Avatar
Hey Todd,
They are a good option too. I covered it in another post. Go HERE .. and scroll down to post #444.
:Cheers:
Ron Sutton Race Technology
Old 05-28-2014, 10:45 PM
Ron in SoCal's Avatar
Originally Posted by Ron Sutton View Post
Hey Todd,
:Cheers:
Hey Ron,
To the best of my knowledge there are three C5/C6 hubs: the standard C6, the Z06 which LG Motorsports sells with the larger rear bearing and the ZR1 which I believe is still only available at the dealer. I could be wrong, but as far as I can tell the ZR1 is the same as the Z06 with the exception of the ABS sensor and inner spline count. Do you know if the load rating is any different for these hubs?
Ron in SoCal
69 Camaro in progress
Old 05-29-2014, 07:04 AM
Ron Sutton's Avatar
Hey Ron,
Hey Ron,
Yes, in that bearing you're referring to, the outer bearing is larger than the inner bearing & it is stronger. This makes the hub rated higher overall. But the weakest bearing is always the bearing that fails, regardless if it's on the inside or outside. The small one in the Z51 bearing is the same size as before, rated at 1060#.
As I mentioned in a previous thread, the bearing engineer I work with said this bearing will wear quicker than the big bearing stuff we're used to racing. So if you check the wheel/hub play & it starts to show excessive, simply replace it. If that happens often, then maybe you need a stronger spindle/bearing/hub assembly. If not, you're probably fine.
Old 05-29-2014, 07:24 AM
Track Junky's Avatar
Ron, can you find out if you can get me a good set of bearings for a C4 hub?
Gaetano Cosentino
Old 05-29-2014, 10:00 AM
You have a Baer hub which is basically a factory GM drum hub.
I remember a few years back...90's someone had a first gen hub that ran a larger outer bearing. I tried searching around but can't seem to find it here. I believe it was Herb Adams could be wrong.
Tobin makes a billet hub but I am unsure what bearings are used.
Old 05-29-2014, 10:06 AM
rickpaw rickpaw is offline
Tobin uses stock replacement Timken bearings for his hubs.
Tu Ho
Old 05-30-2014, 10:08 AM
Leroy Rochester's Avatar
Leroy Rochester Leroy Rochester is offline
On my '67, Maeco used either second gen hubs or SCP hubs on a custom spindle that had the big outer bearing. At the time, Mike really felt that was critical on the race applications. I don't think I've ever seen a first gen throw a shoe though, but I'm sure it's been an issue here and there.
Old 05-29-2014, 10:02 AM
Hey Ron,
Makes perfect sense Ron. Thank you Sir
Ron in SoCal
