Old 07-19-2015, 06:13 AM
67Rally's Avatar
67Rally 67Rally is offline
I ordered the VA Gen IV kit a few days ago from MCB and will be installing it as time permits.
The Following User Says Thank You to 67Rally For This Useful Post:
svtredsnake (08-07-2020)
Old 12-04-2014, 09:59 AM
JON@RESTOMOD AIR JON@RESTOMOD AIR is offline
Default Restomod Air
Originally Posted by Bmf5150 View Post
I read some where that restomod air is uses the classic auto air assembly???not sure if it is true or not
Hey everybody this is Jon with Restomod Air. Although we do use similar evap housings as our sister company, the mounting bracketry/hardware, the internals, the fan and the controller integration is in a completely different solar system. We use a variable speed blower motor and fully customizable accessories that can be made to order. Check us out on www.restomodair.com or send me an email.
Old 12-04-2014, 06:17 PM
dontlifttoshift's Avatar
Would you mind posting a pic of your evaporator coil? Is it integrated with the heater core and if so why did you choose that design?
Donny
Old 01-06-2015, 10:34 AM
RPitts's Avatar
RPitts RPitts is offline
I just bought 2 bulk heads from Restomod great quality! I am in the market for two units one for a 68 and other for 69 Camaro. I would love to see some hose routing pic's of both Vintage and Restomod. I am also looking for ease of evap mounting due to both cars having smoothed fire walls. Any info would be great!
Rob
Old 01-06-2015, 02:06 PM
sleepertime's Avatar
sleepertime sleepertime is offline
Post Pics of my vintage air install on 1969 camaro...
I have the vintage air setup, If you look starting at post #47 you can see how I modified my factory brackets and added some garage made aluminum brackets. I have the smooth firewall.The bolts are thru the inside cowl, not on the outer firewall. It is rock solid when bolted tight.
My build BRNAGN 1969 camaro SS
