Old 06-03-2014, 06:14 PM
intocarss's Avatar
Why the he!! would you want to be in a place like that?
I'm
Old 06-03-2014, 06:23 PM
Ron in SoCal's Avatar
I'm
No you're not. You came out to hang w a car buddy.
Dave might be?
Dustin has a deal w the Mall. He keeps it cool and they let him have Lambos, Ferraris, and cool hot rods show up every Sunday. LAPD (out in force) makes sure he keeps his end of the bargin.
Ron in SoCal
69 Camaro in progress
Old 06-03-2014, 06:37 PM
intocarss's Avatar
Dave might be?
True and true
Old 06-08-2014, 10:03 AM
FETorino's Avatar
FETorino FETorino is offline
It just seems like Ron could have done something with this car in the last few weeks.
Rob in SoCal
Old 06-08-2014, 10:50 AM
intocarss's Avatar
Old 06-08-2014, 10:51 AM
Especially with all that idle time sitting around at car shows.
Old 06-08-2014, 12:27 PM
Track Junky's Avatar
Gaetano Cosentino
Old 06-08-2014, 12:52 PM
fleet's Avatar
fleet fleet is offline
Ronferd, it's that time of the week where you need to give back to the people who look up to you in an online way.
... and jes cuz DP finally rolls under it's own power, don't get a bigg head.
Old 06-08-2014, 01:40 PM
Oh man the gallery is out in full force today!
So...yesterday Rob and I got together to look over my NRG removable hub install and also go take a ride over to QMP. With Sieg remote, I swear if we had added two nickels to what we already had, we might be able to buy one brain. Turns out I might have an old style ididit column because the NRG hub that mounts to the column bottoms out against the column when tightening the lock nut on the splined shaft. That results in not being able to turn the wheel. Crazy thing is it's only positioned by a C-clip, so I used one size larger additional clips as spacers and that did the trick. None of us are totally comfortable with that solution so I'm calling ididit and NRG tomorrow. Then of course there's the horn button position and wiring. NRG/Momo give you multiple parts to install in foreign, domestic and aftermarket wheels so we finally figured out the right combo. Lastly, the ground wire connectors between the Momo horn button and the NRG wheel mount are both male. 20 minute job was done way later in the day
The trip over to QMP was fun. Brad is working on his own head program and we got to compare a few different designs from the Mast/Mozez mamma jammas to WCCH, some large Hemi heads and more. Fun stuff. I finally got bored with Rob's FE motor NASCAR history lesson babble so I dragged him outta there and we both hit the road home.
Today I took the car out to do some testing. I intended to season the rotors per Baer's specs but they're still fresh and you're supposed to wait until you get enough miles on them to get rid of the zinc plating before starting the procedure. So I went for a putt instead and ended up at the Rock Store. Fun ride through the canyons. Had a C6 behind me at a couple of points and lost him quickly. We were driving about 7/10s so maybe he wasn't trying, but my ego is intact . My driving report - I'm trying to get used to the steering input. Seems different at times and I need to look into it. Feedback is good, but power assist sometimes isn't there and slow/medium/high speed has nothing to do with it. Weird, I know, but that's what break in is for, right? Under spirited street/canyon driving the tires and suspension stick surprisingly well at this point. I got a little sense of slip angle and teeny, tiny push (again 7/10ths or so) and that's what I was looking for. Motor and drivetrain rocks the house and at one point I had it past 5k in 5th.
F'n car rocks, Just a fun, fun ride.
Oh, I'll upload a couple pics later. Vid next time out for sure!
Ron in SoCal
