Old 06-08-2014, 10:42 AM
Formula43 Wheel's Avatar
Formula43 Wheel Formula43 Wheel is offline
Here's some links to some tools I use and would recommend if your doing installation yourself.
I purchased a red floor jack from Costco 4yrs ago and it is still working great and we use it for many other unintended uses in our shop like moving large machines and equipment around. It's all steel and low profile, but unfortunately not made in the USA. I couldn't find a link to it, but I believe it was just over $100.00.
Portable air compressor:
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Thin Wall Plastic Protected Sockets: http://www.amazon.com/Chicago-Pneuma...ref=pd_cp_hi_1
http://www.amazon.com/Titan-21092-Dr...EAVN7CXE0GBNQ5
Lug Nuts McGard 3/4"/19mm Hex, Bulge Style, 60 degree cone seat. We stock 1/2X20 and 12mmX1.5 in chrome and black closed end style. For open end race style lug nuts and studs contact Curtis at MSI Racing Products. They supply many NASCAR, IMSA, Continental and World Challenge pro race teams and are made in the USA. He also can custom make whatever you want as well. http://www.msiracingproducts.com/
Valve stems, please contact us directly as we only use a high quality metal TUV approved German made valve stems from a company called "Alligator". We have two styles Long and Short. Almost all of our PT applications would use our short style. It is important not to over torque the valve stem on the wheel as it will crush the grommet and cause it to crack faster causing a leak. We hand tighten them with a socket until the grommet starts to bulge or mushroom and is tight enough to not spin in the hole. A small drop of blue/med. thread locker is a good idea as well. A simple leak can cause a blow-out and thousands in damage to your PT car. A simple way to check for a valve stem leak is to spray some foam style glass clean on it and look for a bubbles.
Torque Wrench, I sell this high quality made in the USA torque that is accurate and made for a lifetime of service. I prefer the split beam, dial and click style over a digital. Precision Instruments makes torque wrenches for some of the highest quality tool manufactures. So your not paying the extreme mark-up and logo. I'm offering these to Lat-G members for $215.00 each, plus shipping. http://www.torqwrench.com/tools/item...kCode=C3FR250F
The above are simply suggested items I use and recommend. I'm not a car builder, but believe these items are of great value and quality to the do it yourself garage person that wants to do more on his own. As you can see, we do not sell many of the above items, as our core business is building great wheels.
I appreciate any input and understand some or many of you already have these and much more!
Old 06-08-2014, 12:37 PM
HMA's Avatar
HMA HMA is offline
Travis,
I know you are a fan of the McGard lug nuts. For open end lug nuts what is your expierence/ what do you think of the monster lugs?
For polishing the aluminum hoops what polish do you recommend and do you polish them a certain direction. Thanks
Evan
67 Camaro RS
Old 06-08-2014, 02:47 PM
Hello Evan, I was just about to give you a shout out as I'm heading your way on the 22nd of this month. I would love to see and go for a ride in your Camaro, dinner is on me!
I prefer a closed style lug nut over open style as the closed style keeps any moisture, debri, etc. out of the contact area (thread & stud). I also cannot recommend using anti seize as this can cause for an inaccurate torque reading and possibly cause the nut to loosen. If you're actively tracking/racing your car then your studs and nuts will wear must faster and should be inspected or replace after X amount of time. This is why using a good high quality lugnut and stud combo like , McGard, ARP or MSI are important. Most studs will have a corrosion resistant coating. I've found the studs that do not have any coating on them are made overseas with lower quality metals and strip, break, corrode easily.
For open lugnuts I would recommend MSI. Very high quality, but only available in black.
Thanks and hopefully see you soon!
Old 06-08-2014, 04:14 PM
HMA's Avatar
HMA HMA is offline
Absolutely Travis, if you are around Monday I can get you in to our simulator and let you play a bit. Give me a call this week and we'll get something going.
-Evan
67 Camaro RS
Old 06-08-2014, 04:25 PM
On the Monster lug nuts they look nice but will hang out past the wheel center lug pocket area which might not be appealing to some due to the length.
Benefits of McGard nuts are:
http://www.mcgard.com/index.php/auto...-nutslug-bolts
Also, the bulge style cone seat lugnut has more surface contact area than the standard 13/16" hex nuts. The 3/4"/19mm hex give you more room to get the socket in the lug pocket without nicking the lug pocket surface.
I prefer to hand thread them on rather than using a impact.
Old 06-08-2014, 04:36 PM
The last item that hasn't come up for quite some time is locking lug nuts. They work fine until you lose the key to get them off.
Normally you don't realize you've lost this special socket key until you really need the wheel and tire off.
Here in Detroit, it's allot of work to jack up the car and remove/steal the wheels. It's much easier to steal the whole car.
Old 06-09-2014, 02:58 AM
latoracing's Avatar
latoracing latoracing is offline
Originally Posted by HMA View Post
Travis,
Evan
I bought Monster lug nuts for my RAD 14 wheel set up. I am running 3" long wheel studs and needed an open ended nut. They look to be a quality part, and they have a longer body to help get them on and off the studs. A standard open ended nut would be way down inside of the pocket. I haven't mocked my wheels up on the suspension as of yet, but here is an example of what they would look like. I took this when we were checking hub fitment before final finishing.
Old 06-09-2014, 05:07 AM
HMA's Avatar
HMA HMA is offline
That is a great looking wheel. You will absolutely love them. Here is a picture of my RAD10s with black monster lugs. I have 3 inch studs as well so I needed the open end lugs. Just curious what everyone else is running.
-Evan
67 Camaro RS
Old 06-09-2014, 06:23 AM
They look great on both guys! Thank your for posting pics.
Now if you really want to get light weight then we can go with titanium lug nuts! Cha Ching ! $$$$
Old 06-09-2014, 07:37 AM
Bryan O's Avatar
Bryan O Bryan O is offline
I'm looking forward to the "installation" part of your instructions. Should be soon.
Bryan
Project Alchemy
https://lateral-g.net/forums/showthread.php4?t=29820
