Old 08-06-2006, 12:57 PM
Obsin71Ls1 Obsin71Ls1 is offline
Originally Posted by tyoneal
Thanks for the feedback guys.
I think if you put certain Corvette parts on the car, wheel sensors would come with them, right?
I'm old tech (unfortunitly) and trying to get up to speed, so I ask:
EFI needs a computer to work, Computer controlling a 4l80e is the hot set up, ABS also need a computer. This being said, Is there a primary computer that communicates with all of these or, is there one computer that will control all of these, or does it just depend on the car?
What computer technology is available for the 1st Gen Camaro's?
Sorry about these being so elementary.
Thanks,
tyoneal
The physics behind ABS and ASR is simple, retrofitting it is another story. At the wheel there is a tone ring (ring with teeth) and sensor (permanent magnet and coil). As the teeth of the ring pass by the magnet, the magnetic field expands and collapses, generating an ac voltage in the coil. The coil sends the ac voltage to the EBCM which converts it to a digital signal from which it determines the wheel speed.
If the wheels lock up, the EBCM sense an abrupt change in the voltage and interferes with the braking. on the other hand if you loose traction, the computer sense an abrupt increase in voltage and interferes.
what makes it hard to retrofit ABS is getting the right tone ring and sensor that produce voltage within the range of the EBCM. Its also sucks that the parameters of most ABS computers cannot be changed.
