Old 06-12-2014, 10:49 AM
CamaroMike's Avatar
CamaroMike CamaroMike is offline
Its highly recommended to get a proper dyno/retune unless you have the factory exhaust manifolds and airbox.
I just did the same thing, its very pricey. All the small stuff adds up quick. Took me $5k to do my ls swap from a truck engine and I got good deals on all my parts. If you switch to a ls1 front drive you have to do the balancer as well, the truck balancer sticks out too far.
What year camaro is it going in?
Alabama
1969 Camaro
1978 Camaro
Old 06-12-2014, 11:12 AM
6carmello8 6carmello8 is offline
It's a 1968 Camaro. I have the ls swap 1/7/8" Dynatech headers and will have an Ls1 manifold and an filter in fornt like most...so I probably should get a tune. I didn't know that the balancer sticks out too far but I have one from an Ls1 so thank god.
Old 06-12-2014, 11:18 AM
OBeer-WAN-Kenobi's Avatar
You can check out Kwik Performance as well. They have a few different options and you usually can choose which accessory drive you are starting with be it truck, camaro/gto, or corvette length.
http://www.kwikperf.com/
I'm running a GTO accessory drive on my '69 Camaro and using a Kwik Performance A/C bracket.
I should mention that Wayne at Kwik Performance is extremely helpful and always seems happy to talk to a guy.
I had to cut out a section of the sub frame to fit my alternator in the factory GTO/Fbody position. The GTO alternator is a bit smaller than the Fbody one, which helps.
There should be some pictures of the operation in my build thread in my signature.
Also, I think Holley is making some accessory drive brackets now but I haven't seen them in person.
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
Old 06-12-2014, 11:41 AM
Wow thank you for this!
Old 06-13-2014, 04:21 AM
rickpaw rickpaw is offline
I "think" the stock truck injectors won't work with LS1 fuel rail, since they're too tall for the lower profile LS1 rail. I was going to do the same thing for my swap and decided against it.
Holley makes decent set up. I'm running Holley accessory drive on my Firebird. Well thought out set up, the instructions were very good.
Tu Ho
Old 06-13-2014, 04:21 PM
Thanks for the input. Luckily I was able to source a complete ls1 with injectors, rail and tb of craigslist for $260. But I still need a retune and MAF...
