Old 06-20-2014, 11:24 AM
rickpaw rickpaw is offline
Default Adjusting door without removing fender?
Guys,
Is there a way to adjust a door on a 67 Firebird without removing the fenders? I can access the bolts on the top hinge using S-shape wrench, but the bottom hinge may be tricky.
Tu Ho
Old 06-20-2014, 11:47 AM
bdahlg68's Avatar
bdahlg68 bdahlg68 is offline
Originally Posted by rickpaw View Post
Guys,
That's a tough one. I would say that even if you get them loose getting the door adjusted and the bolts tightened back up will be even more difficult. What kind of adjustment is needed? Do you need to get to all the bolts in both the door and the body?
Brian
1968 Pontiac Firebird
1989 Ford Mustang
Old 06-22-2014, 08:35 AM
The issue here is the pass side door glass does not go all the way to the roof weather seal (there's a gap about 1/16"), and thought about raising the door to close the gap.
Come to think of it, looks like I need to readjust the glass, not the door, as I have decent door gap all the way around.
Tu Ho
