Old 06-23-2014, 11:42 PM
DBasher's Avatar
DBasher DBasher is offline
Default Venting the rear axle
How much of an axle breather is needed? This picture was taken of Greg's Mustang and I don't understand why such a big can....When I played off-road we'd just run the vent high enough to stay out of the water, no can just a filter and check valve, I do realize it was low rpm compared to a track car.
I'm putting together my 9" and would like to understand this a bit better.
Dan
Old 06-24-2014, 06:29 PM
DBasher's Avatar
Ok, let me ask this.
I'm putting in the axle seals that are close to the 3rd member, where do I now vent the differential?
Dan
Old 06-24-2014, 09:15 PM
I'd vent the pumpkin housing -- vent installed HIGH -- and NOT on the gear side as they'll sling oil at it.
It will also need to be large enough in diameter that it doesn't push oil in the tube and then trying to vent the gas - it pushes the oil up the tube. Had that issue on my '32
A race track doesn't want ANY grease or fluids on the track whatsoever -- so everything MUST be vented to a catch can with some kind of breather/retention... including valve covers etc.
Old 06-24-2014, 10:54 PM
DBasher's Avatar
Thanks Greg
I got the first and last paragraph right off the bat, had to read the second a couple times, slower each time. Think I got it now.
Dan
Old 06-25-2014, 06:33 AM
Originally Posted by DBasher View Post
Thanks Greg
Dan
A
RACE
TRACK
DOES'T
WANT
ANY
GREASE
OR
FLUIDS
ON
THE
TRACK
WHATSOEVER
DASH
DASH
LOL
Old 06-25-2014, 07:41 AM
DBasher's Avatar
Hardy har har! You funny guy. Are you wearing your yellow or green cotton pants today... LOL!
Old 06-25-2014, 08:20 AM
A coat if many colors. But I'm on the airplane to sun valkey beachside I do not have to go to work. <sticking tongue out>
Old 06-25-2014, 01:18 PM
op,
plus catch cans don't come in too many sizes. That ones a universal type.
Back in the old days we use to use clear plastic fuel filters with 3/8" ports. -bout 2" diameter. The oil that gets pushed up goes into the filter then drains back down. The key, you want it to drain back and not fill the can.
Old 06-25-2014, 01:21 PM
Greg is right, you need a large hose. We used the Fram G12 filter's if you wanna go the cheap and easy route. Hook up to the well side not the filter side.
Old 06-25-2014, 11:17 PM
Vince--this is the kind of idea I like. I am going to steal it now, especially since I have one of those old-school filters in one of my garage cabinets right now (along with two really sweet looking eBay-sourced canisters)...
I'll need to place more cool steel tubing in my trunk first, however, so as to have a fashionable place to mount the can...
op,
