Old 06-30-2014, 11:09 AM
Ron Sutton's Avatar
Okie Dokie ...
In road racing, we use shocks with quick disconnect hose canisters. They typically come with the shocks from the manufacturer. I "thought" the aftermarket quick disconnects (that hold pressure) we use for brake lines, hydraulic clutch lines, etc ... might work. Not. Because the Ridetech hoses uses an ORB fitting with special threads, the commonly available hose quick disconnects (with AN or NPT Threads) will not connect.
But Seals It DOES offer split 2-piece seals that are 4.5" OD to cover the 3" holes for the canister to go through, just as Herb mentioned above. I carry them HERE.
Reminder: To those that don't already know this ... do not disconnect the hoses off your shocks ... as pressure & oil will come out.
Ron Sutton Race Technology
Old 07-01-2014, 07:01 PM
Buick Grand National Guy Buick Grand National Guy is offline
Default Mounting remote shock reservoirs...rear
I mounted mine to underside of my 84 Grand National frame behind wheel.
Copied location from Ridetech's Chevelle. FWIW, the adjusting screw is sealed against weather so rain, dust, etc coming off rear tires will not be a problem.
Conrad
Original owner of 1974 Z28. Ordered car with 4 speed, LT, Air Conditioning. Numbers matching car. Now equipped with Edelbrock Pro Flow fuel injection, 96 Zette Wheels, B-Car front disk, WS6 rear disk.
Also original owner of much-modified 1984 Grand National. Ridetech front & Detroit Speed rear control arms/sway bars Ridetech 3-way coil overs. Champion aluminum heads & intake. Comp roller hydraulic cam. CF hood, fiberglass bumpers. Baer 6P (2-piece rotors) 14" front & 13" rear brakes.
