Closed Thread
Old 07-03-2014, 11:23 AM
buickfunnycar.com's Avatar
Thumbs up 1969 Camaro X-77 Z/28 for sale..
Item Location (City/State):Marina,CA
Price:$65k/OBO
Description: Well guys,have finally decided to part with my '69 Z/28,with the funny car project in full swing and my '28 roadster in paint,I've just completely lost interest and now it's time for someone else to enjoy this car.
New odometer shows just 1,441 miles since restoration,car has approximately 62k total miles,here's the description:
Norwood X77 built,originally code 59 Frost Green but changed color to Dupont Chromabase '00-'05 Corvette Millennium Yellow after complete restoration in 2007.
Chevy High Performance August 2007 cover car,Flowmaster 2008 calendar cover car, also used in numerous Flowmaster print ads.
Professionally built 554hp 383 stroker by Chad Golen in Hudson,NH,car was dynoed just shy of 431rwhp and 391 lb ft torque and features the following components:
4-bolt main high-nickel block,ARP main studs,inspected by MPI process,decked,bored,honed w/torque plates,Clevite cam bearings and Pioneer freeze plugs installed.
Patriot 225cc CNC ported aluminum heads (three angle performance valve job/Combustion chamber 68cc/Intake runners 225cc/Intake valves stainless steel 2.02"/Exhaust valves stainless steel 1.60"/Patriot Gold series valve springs/Comp Cams Pro Magnum roller rockers 1.5 ratio)
Eagle 4340 forged steel crank (dynamically balanced)
Eagle 4340 forged steel H-beam rods (6"/full floating pins)
SRP forged pistons (11:1.1 compression)
Comp Cams solid roller cam (Duration-intake 248 @ .50"/exhaust 254 @ .50" Lift-intake .576"/exhaust .582"/Lobe separation 110)
Comp Cams hardened pushrods
Cloyes true roller timing set
Melling high volume pump,pick up tube and HD drive
Canton 6-qt road race pan
Fel Pro performance gasket set
Edlebrock Victor Jr intake manifold w/ARP stainless steel intake bolts
Pro Systems Blaster series carburetor (true 840 cfm,flowed specifically for this engine)
MSD Pro Billet distributor
MSD coil/MSD wires
Weiand high performance aluminum water pump
Carter performance fuel pump
Car was completely restored in 2007, exterior prepped and painted, complete new interior in stock GM black vinyl by Rick's Upholstery using as many NOS GM parts as possible.Stock Z/28 console gauge package and GM Z/28 rosewood steering wheel
Car has as-born with M-21 transmission which was professional rebuilt by Mike Stacks at Standard Transmission with new Hurst shifter and linkage/date codes available upon request
Car has as-born with 12-bolt posi rear end completely rebuilt/date codes available upon request
Centerforce dual-friction performance clutch
Suspension is stock GM Z28 with the exception of Herb Adams/VSE front springs, front 1 1/4" sway bar,rear mid-eye leaf springs w/ 7/8" rear sway bar, 1" lowering blocks and Koni adjustable shocks all-around.
Stock Z/28 front disc/rear drum brakes
Power Steering Pros quick-ratio MANUAL steering box/2.5 turns lock-to-lock
Competition Engineering subframe connectors
Custom 3" exhaust by Howard Cauntay @ All-American Muffler with QTP electric cut outs and side exhaust
Marquez billet rear light housings and carbon fiber fender braces
Custom Undercover top and bottom close-out panels
Custom carbon fiber front spoiler
Rushforth Superspoke wheels/brushed finish with smoked titanium powdercoat,sizes are as follows:
Fronts 18x8 (4.75" b/s) Nitto N555 245/45's
Rears 18x10 (5.685" b/s) Nitto N555 275/40's
Car is headed to Michael Young's Speed & Custom soon for a super-tune and complete nut & bolt check of the car, he just did my 1970 Z/28 Camaro which I recently sold as well as my 1970 Chevelle SS454 that was sold late last year and will NOT be available to be driven until August 1st at the earliest. If I get some serious interest in the car, I can see about speeding up this process and having the car completed sooner.
My original plan is to run this car through the Mecum auction on August 15th here in Monterey but I have not committed yet to doing so I am putting feelers out here first to gauge the interest in the car before I consign the car.
All magazine articles,calendars and any other advertisement's with the car in it comes with the sale.
I can be reached here by PM or directly by cell phone at (831) 295-2370
Please let me know if there is any information that I left out and thanks in advance for looking guys!
www.buickfunnycar.com
Old 07-03-2014, 11:31 AM
Wink Few more...
I love how the wheels look when there's isn't much sunlight on them, they look very smokey:
Old 07-03-2014, 08:03 PM
rpoz20's Avatar
rpoz20 rpoz20 is offline
Very nice car. I didn't know all the details until now, but I've had the full sideview shot as the background pic on one of my computer monitors for years since I first came across it on the web. In fact, I recall originally using a pic when the car had the VF40's on it and then updating the pic when the Rushforths were installed. Your car was inspiration for me to buy my own '69.
GLWS!
Jim
'69 Camaro
'71 SS454 Monte Carlo (RPO Z20)
Old 07-04-2014, 08:49 AM
Thank you Jim, I appreciate the kind words.
When I was driving and promoting this car, I would answer maybe 15-20 questions/monthly regarding the wheels and stance so it makes me happy knowing the car was an inspiration and a help to some...someone will be getting a well-sorted out clean Z/28.
Old 07-04-2014, 06:53 PM
Z06Joe Z06Joe is offline
That's an amazing car!! Are those covers for the lights, or will the light actually shine through??
Old 07-05-2014, 02:40 PM
Thanks, the covers are just to keep the Trans-Am theme going,they come off if the lights need to be operated...
Old 07-07-2014, 05:07 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Awesome, awesome car John.
Your Chevelle was my favorite out of all 3, but they are all very nice and very clean.
GLWS
Old 07-10-2014, 08:52 PM
Neil B Neil B is offline
Definitely one of my all-time favorites. All business and perfect stance.
Old 07-11-2014, 03:04 PM
Thumbs up Thanks guys...!
Weekend bump before I commit the car for the Mecum Monterey auction next month...
Old 07-14-2014, 10:55 AM
Well committed the car to Mecum,car goes off Thursday 8/14 between 2-3:30,set the reserve @ $65k,I'll be driving the car across the block...no backing out now.
Wish me luck guys...
Closed Thread
