Go Back   Lateral-g Forums > Technical Discussions > Trucks
Old 07-17-2014, 09:15 AM
Sieg's Avatar
Sieg Sieg is offline
Good News!
Old 08-01-2014, 09:21 PM
ProTouring442's Avatar
Not a lot to show for it, but there has been some serious work going on.
Made the distribution duct for the HVAC.
As you can see, it's becoming a wee-bit tight in the dash!
But it's hung, and the ducts are run.
Installed the gauge panel (hopefully for the last time!). All the gauges work. You can even pull and clear codes with the speedometer!
Modified the overhead console. The speakers are for the CB and scanner. The red lights are my interior lights. Red light doesn't hurt your night vision as much as white.
A couple weeks ago, we picked up a "new" (to us) car for my wife. It's a 1993 300ZX. The thing is nearly perfect! Only 75K on the odometer, and it looks like a 3 year old trade in instead of a 21 year old car.
Had the major service done on it this last week, so it should be good to go. I have a head unit with built in navigation sitting in my living room, just waiting to be installed. Sometime this fall/winter it will get remote start (my wife has MS, and getting into a hot car really sucks the energy out of her).
Today I went for a ride in it--tops off. Found a sweet spot and snapped a few photos of it.
And last, but not least, the critter shot! This cool little guy was flying around while I was working... kind of looks like a painting on velvet, doesn't it?
There you go! As they say, stay tuned!
You ever wonder what medieval cook looked at the guts of a pig and thought, "I bet if you washed out that poop tube, you could stuff it with meat and eat it."
Old 08-01-2014, 11:36 PM
fleetus macmullitz's Avatar
Nice work on the dash.
Plus the very clean looking ZX.
I agree, that is a cool lookin critter.
Old 08-09-2014, 11:35 AM
Nice work its looking good.
Old 09-25-2014, 04:06 PM
Not a lot to show, but there has been Jeepage!
While I think I've taken it apart and reassembled it at least a dozen times over the last few days, the dash is assembled!
I needed to pull the column apart and install an overdrive shift quadrant.
Fortunately, I was able to sneak the old quadrant out and install the new one without completely disassembling the entire top of the column...
Quadrant in and column on its way back together...
And with the correct Jeep wood wheel... :shock:
Old 09-26-2014, 09:48 AM
Evan Iroc-Z Evan Iroc-Z is offline
This update is bull****! Where's the critter picture?
Looks good!
'89 IROC-Z Turbo 3.8 5SPD
LS1 Brakes|Wilwood Prop Valve|LS1 Master Cylinder|Aluminum Driveshaft|LS1 3.42 Rearend|Adj PHB|Adj LCA|LCARB|Koni Struts|Koni Shocks|Adj Caster/Camber Plates|STB|10 Spoke SS Wheels|PHB Relo Kit|Adj TA|SFC|ARAP Based Prom|B&M Short Shifter|Underdrive Pullies|SMOG!|AIR!|Rag Joint!|Magnaflow|Ported Plenum|Misc Stuff
Old 09-26-2014, 01:24 PM
Looks good!
Thank you... I actually really needed that! It's been a rough few weeks.
I'll see what I can scare up.
Old 09-26-2014, 04:46 PM
Well, no creature feature, but I do have an empty turtle shell I found under our house.
Old 09-26-2014, 05:31 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
LMAO Build it!
Curtis
Old 09-29-2014, 10:16 AM
That'll do. Carry on.
