Old 08-21-2014, 05:39 PM
woody80z28's Avatar
woody80z28 woody80z28 is offline
The minute I saw your picture posted up I knew it was my old one...
It's made the rounds! Started life at Kinsler in Michigan... to Seattle... To So Cal... to somewhere else... to you in New York...
I finally gave up on the Accel Dual Sync distributors to run sequential. I was "too early" on their stuff and those distributors caused me nothing but issues. System ran much better in batch mode.
So you had both, ok. It came with two, and also two computers for some reason. I'm pretty familiar with EFI and I didn't find it very user-friendly at all. Two different guys on thirdgen bought the manifold & throttle body. I'm using an old TBI truck distributor I had around for now, maybe it will stay that way? haha Sequential would be nice, you do notice a little difference in the idle...at least I did on my MPFI vs SFI Beretta.
Old 08-21-2014, 06:33 PM
I believe in having "inventory"..... and spares... I'm not the "budget" guy. Back in the day it was hard to find parts for EFI (or anyone that knew anything about anything for that matter). I probably still have parts and pieces for that thing... I know I still have some of the blue anodized linkage.. etc. If parts are uncommon - I buy TWO....
I switched that throttle body set up for an 8 stack... and I swapped out the Accel crap at the first chance I got. That stuff ran okay - but there was (Might still be) the worst supported stuff in the history of man. If you wanted to know something - you had to post it in a tech forum - and then keep checking back to see if they bothered to respond.
Old 08-21-2014, 06:46 PM
Glad you're back on the Z, Woody. Good luck with the plans.
Old 08-22-2014, 02:52 PM
89 RS's Avatar
89 RS 89 RS is offline
Look forward to seeing more, good luck with the build!
Corey
1989 Camaro RS
Old 08-22-2014, 09:10 PM
woody80z28's Avatar
It's nice to be working on it again. I've got a to-do list that is miles long, and some of this stuff has been waiting for too many years. The Camaro was getting neglected after the Beretta "frame off", the truck overhaul and buying a house...and that whole getting married thing. haha
Old 08-22-2014, 06:16 PM
CamaroMike's Avatar
CamaroMike CamaroMike is offline
Hey woody! I remember you from nasty z28 years ago, I cant remember what my name was on there. I think I bought calipers from you. Good to see you still have the car and going at it!
Alabama
1969 Camaro
1978 Camaro
Old 09-01-2014, 08:46 PM
woody80z28's Avatar
Finished up the exhaust today. Everything tucks up really nice. The bottom bolt on the header flanges hang just below the subframe, but that is it, and I rerouted the over the axle pipes for max suspension clearance. I modified the crossmember and the driver's header to keep everything up high. And those SpinTechs are fairly small so they aren't bad to locate. Should sound nasty too! Next thing will be the rear Hotchkis bar install and then cutting off & modifying the mount where the SFCs connect to the SF so it's removable for the rotisserie.
Old 10-09-2014, 08:21 PM
woody80z28's Avatar
Big update! Been burning more metal with the car on the rotisserie...cleaning up some ugly from the 6spd swap and the rear end through the back seat. haha
Reworked the Alston SFCs. I was amazed at how much I could flex them when I cut the ends off to remove the subframe. So I built some heavy brackets with a big gusset and put a couple braces on the SFC tubes to the floor bracing to make them stronger. Now it should be just as strong as the Rasmussen/DSE-style connectors without redoing it all. Welded in the Hotchkis plates for the rear sway bar too.
I finished the fab work on the 6spd hump and boxed in the floor bracing I had to cut for the shifter. Probably not an issue anyway given the solid SF bushings, but can't hurt. Also finished fab on the firewall for the clutch master bracket and filling/smoothing, and added an 1/8" band under the cowl seam where there was a lip. Should be a stronger spot to bolt my G-braces to and will look better when I grind & smooth it.
Cut out the metal on the front lower quarter to access the rusted bracing. The pass side was repaired by the previous guy, but they didn't do anything with the bracing. I'm going to get both of those areas blasted when it goes to the blaster next week, and try to re-fab the bracing if I can see how it should have been. I already have the patch panels to close it back up.
There is also a hint of rust at the bottom of the doors. My body guy says it might not even be worth skinning. Have a look and see what you think. The other rusty spot is the heavy gauge toe box up by the subframe mount. Not sure of the best plan to tackle that. It needs to be structurally solid in that area.
Old 11-09-2014, 08:32 PM
woody80z28's Avatar
Got the car back from the sand blaster finally and I've gotta admit, I'm disappointed with the job. Looks like they half-assed it. Sent the boss at the blaster some pics and they are gonna take it back and do it right.
Not much for rust surprises. Got down to the fiberglass patches from the PO in a couple spots so I can fix it right. Did find a new spot on the cowl to cut up though. Didn't see that one coming.
Doing a couple patches first. And cut out all the rust in the inner rocker/door jamb area of the quarter.
So I knew the PO replaced the exterior sheet metal at the lower quarter...what I did not find out until just now was they wadded the holy rocker full of bondo. So I cut all of that out too.
I also cut out the rusty part of the cowl panel. Borrowed a friend's cheapo HF spot weld cutter and it worked amazing actually. Very impressed. I put a post in the NastyZ swap meet section looking for just that part of the cowl in case someone had to use just the driver side for something. If no luck I'll just buy one and sell off the other half. haha
Finally got everything I need to finish up the underbody once I get it back from the re-blast job. I will be taking the car back over this week. I've got SPI primer and Lizardskin heat & sound coating.
Old 02-07-2015, 01:20 PM
woody80z28's Avatar
OK...been a while.
Blaster re-blasted the car and some more stuff.
Thanks to Kevin Tetz and a guy on the NastyZ facebook I ended up smoothing the firewall further and relocating the wiper motor while I was finishing metal repair.
