Old 09-01-2014, 06:41 PM
I agree with Todd.....
Heat RISES... so whenever I'm working around the headers - I want to be UNDER them not over 'em.
I'd re-route the line close to the block away from the header.
Old 09-01-2014, 06:48 PM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
Thanks Greg.
There is no room along the block for two soft lines with these headers. I'm hoping i can make it work with hard lines otherwise it means a different adapter
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
Old 09-01-2014, 08:44 PM
efs69's Avatar
efs69 efs69 is offline
Hey Chad,
I know what you mean about space but I agree with others about the line. I would look at a remote filter set up and run the lines along the side of the pan if you can. I'm not sure what you're frame and engine look like from the bottom but I would think there has to be a way to do it.
Also my temps don't get as high as yours. What temp do you have the fans set to?
Old 09-01-2014, 09:52 PM
Originally Posted by efs69 View Post
Hey Chad,
I used to have the fan kick on at 200* and off at 195* but after seeing the fan run constantly I set it to kick on at 210 and off at 205 to see if it made a difference. Operating temps really didn't change either way though the fan ran a lot less.
I played with it some more this afternoon and at idle it can get as high as 215*. When I bring up the revs it drops to 205* but today it didn't drop any lower.
I'm running the AFCO LS radiator and a Mark VIII fan so I'd think that is plenty to keep an idling motor cool... I have an open question to Vintage Air and via them to Tuff Stuff who made the water pump about it.
EDIT: on the streets of willow track for the handling challenge coolant temps stayed around 210* even with oil temps at 260*+
Old 09-02-2014, 06:54 AM
If you bring up the RPMS and the car cools off --- I'd be looking at the voltage your electric fan is seeing at idle. I assume you're running a relay -- but perhaps not heavy enough gauge on the power side.
I bought a 37 Ford once that had an overheating problem -- well DOH! The fan was seeing 10 Volts... That was certainly easy to fix.
Old 09-02-2014, 07:11 AM
I hadn't thought of that Greg. I'm using the Mast relay built into their harness. I will double check it.
This could be part of the story but isn't the whole story as I can duplicate this behavior on the freeway with the fan off. I turned the fan off with my laptop and saw stable temps ~210* in 6th gear 70mph but when I ran 4th gear at 70mph the temps dropped to below 200*. So I think there is something else going on too.
Regarding lean vs rich. The car is pretty stinky right now and if I don't clean it builds up a layer of soot on the tail panel so I think it's to rich. Oh and it gets horrible MPG. Around 10mpg around town. A best of 15 on 100% freeway drive.
Old 09-02-2014, 06:01 PM
Sounds like your water pump pulley may be to under driven. Meaning, to big.
To fat can cause high exhaust gas temps as well.
I'd dial in the tune before you worry to much more about temperatures.
