Old 09-08-2014, 11:31 AM
intocarss's Avatar
Default Top Fuel Drag Bike Crash at Santa Pod Raceway
He should buy lots and lots of lotto tickets
Old 09-09-2014, 06:45 AM
Evan Iroc-Z Evan Iroc-Z is offline
Am I seeing this correctly? Did he land on the wheelie bar of his competitor? If so you are absolutely right. Lotto tickets it is!
'89 IROC-Z Turbo 3.8 5SPD
LS1 Brakes|Wilwood Prop Valve|LS1 Master Cylinder|Aluminum Driveshaft|LS1 3.42 Rearend|Adj PHB|Adj LCA|LCARB|Koni Struts|Koni Shocks|Adj Caster/Camber Plates|STB|10 Spoke SS Wheels|PHB Relo Kit|Adj TA|SFC|ARAP Based Prom|B&M Short Shifter|Underdrive Pullies|SMOG!|AIR!|Rag Joint!|Magnaflow|Ported Plenum|Misc Stuff
Old 09-09-2014, 08:48 AM
intocarss's Avatar
Yes he did
Old 09-11-2014, 02:53 AM
yikes what a ride
