Old 08-21-2006, 04:49 PM
mazspeed's Avatar
mazspeed mazspeed is offline
Kind of looks like a 21st subframe.
Old 08-21-2006, 04:57 PM
Mike Hall's Avatar
Mike Hall Mike Hall is offline
Well if you look its a Chassis works subframe with mounting plates for C5 suspension. I guess he gets the frame rails from chassis works and makes the mods for the C5 stuff using his own jigs. I was just wondering if anyone has used this subframe or have more info on how well it performs.
Mike
Old 08-21-2006, 05:55 PM
4mm 4mm is offline
The owner or the shop is selling the car that is pictured on the website and it is not finished.
http://cgi.ebay.com/ebaymotors/Chevr...QQcmdZViewItem
Old 08-21-2006, 06:23 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
Not really. The 21st Century sub has inserts that allow fine tuning of the UCA mounting point, retains the C-5 LCA eccentrics for alignment and is (based solely at looking at the pictures on the Muscle Car Works site) beefier. If you look closely at the linked shot (http://www.musclecarworks.com/subfra...Sub%20Lg11.JPG), the alignment system - washers behind the UCA bushing mounting points - looks (to put it kindly) a little jury-rigged as compared to the C5 setup used on the 21st Century sub. That said it MAY be cost effective.
Old 08-21-2006, 07:09 PM
68protouring454's Avatar
Default 21st
the only thing the eccentrics do is chang ethe angle of the uca, weather its for anti dive or whatever they are a circle track peice, not some ingenious 21st made part
Old 08-21-2006, 09:00 PM
Steve1968LS2's Avatar
Who said they invented it? They are the only people that have incorporated it into a subframe. Or do you think that it's bad to have more options for suspension tuning?
It's nice to have options.. right?
Old 08-21-2006, 09:41 PM
Mkelcy's Avatar
I never claimed they invented it, perhaps nuclear fusion, but not the little inserts. And in any event they (and the LCA eccentrics) are better than the "stacked washer" alignment system.
Old 08-22-2006, 04:25 AM
Default easy
calm down, options are nice, all i am saying is it is a circle track part, yes 21st may be the first to use it i have no idea.
its ok guys verything will be ok
Old 08-22-2006, 06:42 AM
It's all good Jake.. you just sounded like you misunderstood what what was said..
group hug??
Old 08-22-2006, 06:54 AM
Payton King's Avatar
Default the eccentrics are on the lower control arms
and they are the same as on the C5 vette. They actually sourced from the Gm parts counter.
