Old 09-27-2014, 05:27 AM
Piston wise, I'm not sure honestly. Obviously, I need pistons that will work with a stroker crank and 5.7 rods. I'm just not sure what valve relief I need since I haven't even talked with a machine shop or Advanced Induction about heads yet. Ai has some piston info on their website but I want specifics and I'm no where near that point yet.
The block is 4.030 bore so it has been bored out. Casting number is 14093638. I figure I'll just ask $150 for the block if that's not unreasonable. I'll stand behind it too if it turns out to be no good. I haven't found anything that tells me it is not good.
Thanks Scott
