Old 09-27-2014, 01:38 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Originally Posted by Rod P View Post
I don't know how many suspension systems you will find for 1500 bucks worth any thing but you can do something like
Ridetech Adjustable front shocks $350 for the front pair
Ridetech adjustable rear shocks $350 a pair
Helwig front sway bar $178.99
BMR chevelle Lowering spring set of 4 $239.95
$350
$350
$179
$240
TOTAL
$1119 bucks
that's a great start, all great products and the car will handle well, and with the adjustable shocks you can go SUPER smooth for daily driving and stiff for autocross
Chris,
Take the rest of your funds and upgrade the steering box. Lee's, AGR or something like that. You will probably have a few small parts that need to be replaced (old cars always do) also. That along with the Ridetech parts should make for a very nice handling car and a lot of fun without breaking the bank.
I really like that you're not going to crazy with your suspension and realize that there isn't a need to spend more than you have to. Guys get in way to deep sometimes. It's all about balance.
Keep us posted on what you do.
Curtis
Old 09-27-2014, 03:57 PM
A-Guy's Avatar
A-Guy A-Guy is offline
Chris,
Thanks for all the input Curtis, its greatly appreciated! With the setup you recommended, what do you suppose i do about control arms?
Old 09-27-2014, 06:27 PM
Rod P's Avatar
Rod P Rod P is offline
you can leave the arms stock for now, and like a previous poster said upgrade the steering box! you can do the arms later, but for a daily driver the stockers are ok
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 09-27-2014, 11:52 PM
Spiffav8's Avatar
Lateral-g Moderator
^^^There's your answer^^^
If you wanted to take it up one more level, you could do uppers and lower along with a upgraded spindle later on. If it where me, I would look at upgrading the brakes at that time and adding discs to all four corners. That way you only have to take it apart once.
Taking the upgrades in stages will really make you appreciate the improvements and keep the car on the road... which is really what it's all about.
Curtis
Old 09-28-2014, 05:56 AM
67goatman455 67goatman455 is offline
If low on funds you could always do the Jeep Grand Cherokee steering box. It will work on my car anyways, i assume it does on a 72 also.
As far as suspension i wouldn't dump my money into the ridetech shocks, there is no need for it if your just cruising around, i would lean more towards something like Bilstein HD shocks and SPC springs.
$350 for all four shocks http://scandc.com/new/node/677
$300 for springs http://scandc.com/new/node/104
1967 GTO, LS2 T56
WILWOOD FORGELINE RIDETECH
$10k Budget driver/ track car
Old 09-29-2014, 12:04 PM
BMR Sales's Avatar
Our Stage 1 will fit under your Budget
http://www.bmrsuspension.com/?page=p...=75&superpro=0
Our Stage 2 is a little above it
http://www.bmrsuspension.com/?page=p...=77&superpro=0
Old 09-29-2014, 12:52 PM
Rod P's Avatar
bilsteins from the site you recommended are 89 each front and 99 each rear, our's are 125 each with a LIFETIME warranty??? If you want a non adjustable...I always recommend the upgrade to adjustable because not everyone's like of ride quality is the same, and IF you wanted to try SCCA, Goodguys, Optima, Motorstate, Run to the Hills, Run to Music City, Ohio Musclecar Challenge, Detroit Speeds Southern Slam, or any of the roughly 30 events our group has just adjust the shocks to the track event and be competitive.....
Rod Prouty
Bangshift Stories
Old 09-29-2014, 01:48 PM
A-Guy's Avatar
Man!!! All this info is outstanding and i am so very appreciative of all the input and guidance! Thank you all and i will post up what i decide to do.
Chris
