Old 09-27-2014, 07:32 PM
Did you use teflon tape on any of the line fittings? Could you have a piece of that tape interfering with the fluid - lots of pressure pushing but ZERO retracting and a little bit of that tape could retain enough pressure to hold the caliper out??
Is the caliper piston(s) "free" when you take it off the rotor and push the pad back? Is it still free if installed on the rotor and you attempt to push it back?
If it's not - I agree with Vegas - could be a defective piece.
Old 09-27-2014, 07:34 PM
Also -- make sure it's the pad/caliper that's the issue --- can you see the mounting bolts?? Make sure you've installed the right bolts -- I've seen them where they go thru the bracket and are interfering with the rotor. Could explain why it seems fine until you reinstall the assembly.
Old 09-28-2014, 06:21 AM
J-440's Avatar
J-440 J-440 is offline
Am using braided steel line with no tape whatsoever. The outside pad slides out no problem, but the inside pad I have to pry out. The pistons are only about 1/8" sticking out on the defective side, the other side the pistons are flush with the caliper.
What causes the pistons to retract anyway? When you release the pedal, is a suction created to draw the pistons away from the pads?
68 Charger, 440SC, EFI, 6-speed
Old 09-28-2014, 06:39 AM
Good question about the suction -- there might be a teeny amount - but it would be minuscule. The pad is generally just resting on the rotor and the flex of the rotor will push the pad back (we're talking really small movements here). New cars with fancy ABS brakes will sometimes have a feature where if you turn on your wipers they figure your brakes (rotors) are wet and they'll apply a small amount of pressure just to dry them off.
Sounds to me like you have a bad caliper.
Since it's only the one caliper that's acting up... otherwise I'd be asking you about your complete system - like your residual valve etc. And some Masters have residual valves built in.. but your other caliper is acting normal so we're just worried about the one.
Old 09-28-2014, 08:34 AM
68Cuda 68Cuda is offline
The flex of the square O-Ring seal and the knock back from any rotor run out is what draws the pistons back. If it is easy enough to swap the caliper left to right then try that to determine if it is caliper or the system. (Are your bleeders and bypass easy to swap) Does your mount have shims to center the caliper? Sounds like you might be off center also. All this stuff is harder to troubleshoot when you have to rely on someone else to look and touch...
Michael
Plano, TX
1968 Barracuda Notchback
Body & Paint:
http://www.forabodiesonly.com/mopar/...dy-2014.10252/
Engine:
http://www.forabodiesonly.com/mopar/...ictures.10230/
Old 09-28-2014, 09:26 AM
Good call Michael, the caliper should be centered on the rotor. It's not uncommon to need to pry on a brake pad to remove it. I'd check the center of the caliper and drive it.
Old 09-28-2014, 09:34 AM
J-440's Avatar
That's what I thought the problem was at first, that the caliper wasn't properly shimmed to fit over the rotor. But it's fine. Unfortunately I can't swap calipers, it's a one size fit only system. I'll keep yall informed in case this happens to anyone else. Thanks for all the input!!
Old 09-28-2014, 01:51 PM
J-440's Avatar
Time to invest in another vacuum bleeder kit bc my old one just won't cut it anymore. Had my wife pump the brakes and quite a bit of air came out. Did the passenger side and now everything's back to normal. Life is good!
