Old 10-07-2014, 10:08 PM
Sieg's Avatar
Sieg Sieg is offline
Originally Posted by Bonebuster29 View Post
Don't want to cut the tunnel...
That was just about the easiest part of my entire install.
I can't say enough how please I am with my T56 mag 3 years later. I had a deposit down on a TKO and it would have been a huge mistake. You don't hear anybody say "I wish I would have went with the TKO instead" but on the other hand you do hear "I should or wish I would have installed the T56."
Besides the gear ratio compromises you have the high rpm shift issues that don't appear to have a guaranteed aftermarket cure.
You may not have to cut. Some do, some don't. I'd plan on it, but these cars vary so much that you just don't know until it's apart and test fit.
Ultimately it's your choice.
Old 10-07-2014, 10:12 PM
If he isn't revving past 6500 rpm and beating the hell out of it, probably not an issue.
I don't always see the need for the double overdrive even though many say it's great.... even those who don't have one.
Old 10-07-2014, 10:19 PM
Sieg's Avatar
3:73's with 26.5" tire and 2,100 @ 72 mph is one good reason.
Though that doesn't apply to cars that don't get driven or live on jack stands.
Old 10-08-2014, 12:07 AM
Richio1's Avatar
Richio1 Richio1 is offline
I am more than happy with my TKO 600. I had the same concerns about cutting the tunnel... but I do everything backwards and decided to upgrade the tranny after the build was done and the interior was in. That made my decision a little easier.
I know everyone loves their T56 and it probably shifts a little better but for me, so far, I dont see the need. It is fine on the highway. I run 3.73's with a 19" wheel (dont recall how tall) and the RPM's are in the 2100-2600 on the highway which I am fine with. Not sure I'd get it into 6th often enough.
The mileage and smileage is way better than with my old Muncie. So much more enjoyable to drive.
You cant go wrong either way.
Jeff
Lateral-g Feature - https://lateral-g.net/forums/showthread.php4?t=44186
Build thread - https://lateral-g.net/forums/show...ght=brownstone
Special thanks to Matt's Classic Bowties along with
Old 10-08-2014, 07:12 AM
ilikeike's Avatar
ilikeike ilikeike is offline
I got a quote from Hurst for their TKO 600 kit, I'm also going to look at American Powertrain before I buy,and compare parts/price at that time.
The T-56 would be nice,but I don't even drive my daily driver on the highway much,so I'm not too concerned with a double OD in my weekend toy.
Old 10-10-2014, 03:16 PM
Bonebuster29 Bonebuster29 is offline
This is very true! Problem is my dynamat, and heat barrier as well as the interior is already installed... Yes not a HUGE job to uninstall but the dyna mat would be a bitch.
Where is a good source to buy transmissions though? I guess a T56 isn't completely out of the question, just not sure the cost difference on the tranny and mating it with an LS3 would be...
68 Firebird - Build still in progress
DSE Speed kit 3, Glink rear, Moser 12bolt, LS3 540hp, T-56 Mag, Willwood Areo brakes...
Old 10-10-2014, 03:40 PM
A tko 600 belongs in one place, a school bus. Hated mine with an absolute passion. Two different clutches, put in carbon fiber synchros, different shifter, adjusted it by cluctch air gap...
I just drove a close ratio t56 magnum. Wow, what a nice transmission.
Spend the money once and do it right. Did I tell you how much I hated my tko 600.
Old 10-10-2014, 03:48 PM
You clearly didn't change the one thing that mattered......
the driver.
Old 10-10-2014, 04:26 PM
Dick Trickle couldn't have shifted that UPS Truck trans. hahahaha
Old 10-21-2014, 12:17 PM
badazz81z28 badazz81z28 is offline
No question, driver and installation error.
1. A transmission doesn't burn up clutches or cause clutch release problems
2. Most shifting issues are caused by clutch or bell-housing alignment.
3. The shifting feel was really no different than a Muncie or t-10 (so they suck too?)
I have had my TKO for a few years and has been a flawless transmission. The ONLY reason I want a Magnum is for 6th gear (.50). I went with the TKO initially, is because I had an OEM T56 and too much cutting. TKO was supposed to be a no cut option....but wasn't.
