Old 10-21-2014, 08:24 AM
gerno's Avatar
gerno gerno is offline
Default Your list of must have shop equipment
Looks like soon I'll be moving out of the duplex I'm in and into a house with a full 2 car garage and a nice little 25x30 shop in the back yard. It's a little ways away from the fun of downtown Austin so I also want to be sure I have all the tools to play with. No use in buying it and not being able to use it.
As of now I have many of the basic tools but am curious what tools you guys have that I should consider purchasing and rating by most important first. My budget for new tools will most likely be ~10-15K which I know can go very fast. If there is already a thread with this info let me know. I searched for a bit but did't find anything specific.
What I think I have, stuff has been stored for ~2 years now so hard to remember
Large roller box full of hand tools.
1/2" and 3/8 impact guns
Decent smaller Harbor freight press
Bead blast cabinet
Lincoln 155 MIG
Thermal Arc Fab 250 MIG
Metal chop saw (with a blade, not abrasive)
2 floor jacks
Lots of 3 and 6 ton jack stands
2k winch to pull cars in and out of the shop
double flaring tools and small tube benders
Engine hoist
Multiple angle grinders
Cheaper bench grinder
A couple cheaper vises
Small 30 gallon compressor that's too slow and noisy
Harbor freight solvent tank
Things I am considering to purchase
Large 220v ~80 gallon compressor
Build some nice solid steel tables
Tubing bender - most likely JD2 but open to suggestions
Tubing notcher - not sure what brand
Plasma cutter
Belt/Disc sander
TIG - I have no idea how to use it but really want to learn....
Some kind of crane system in the shop to keep from getting more hernia's
Lathe - thinking 6"x 3ft or so
Mill - either small bench top or used large one
Stomp Shear - used 3 ft or so
Decent bead roller
Metal Bandshaw
Dimple dies
Smaller metal break
Lift - Possibly, debating if it will take too much room
Smaller CNC Plasma table - thinking could also use to make some side $$
English wheel
Planishing hammer
Shrinker/Stretcher
Alignment tools
Race scales
