Old 08-23-2006, 01:10 AM
novanutcase's Avatar
novanutcase novanutcase is offline
Originally Posted by Mike Hall
Morrison does not have a bolt on front clip that i can find.
Mike
Weld In........ but you have to ask for it. They don't sell it as a kit so much as they will make it for the car you have!
Old 08-23-2006, 08:21 PM
BThibodeaux BThibodeaux is offline
Default Inner wheel housing opening relocate on WD subframe
OK, this may not be the thread to ask this question, but I have a querie. I spent this evening placing the stock inner fender wells over my WD subframe set up for C4 trying to determine how far back I need to move the opening. Wayne gave a general measurment of 3", but I came up with only about 2.25". Can I please get some feedback from those who have done it? How far did you move your openings, and did you do any additional trimming from the front or anywhere else to get it to look like you wanted it?
Jody? Anyone?
Thanks guys,
BT
Old 08-23-2006, 09:48 PM
Jody? Anyone?
Thanks guys,
BT
I believe mine cleared without any trimming, but was not centered with the a-arms. I had just coated the inner fenders so I left it. I believe DSE did the surgery later for Stuart.
Distance would be 2-3" as I remember, but only for looks.
Old 08-23-2006, 09:51 PM
Yes, only for looks. Sorry, I am kind of anal that way. Thank you so much for the super quick reply!
BT
Old 08-25-2006, 12:10 AM
Originally Posted by Steve1968LS2
To run the T56 I raised the tunnel just under 2-inches 21st Century supplied me with the parts to raise the tunnel. If I would have ran a different trans I wouldn't of had to raise it. .
story on my subframe install will be in the December issue of PHR. If you need specific pics (of the trans tunnel mods) just let me know. I have several hundred pics of the install.
Hello Steve!!
Could you make a small "how to fit T56" in Lateral-g tech section? I think this would be a good technical help for many of us!!!
63 Z06
Old 08-25-2006, 10:08 AM
Originally Posted by Bowtieracing
Hello Steve!!
Here you go...
https://lateral-g.net/tech_articles/ats_t56_install/
Tyler
Old 08-25-2006, 10:31 AM
Originally Posted by Teetoe_Jones
eeh sorry! Thats a good one!! I meant the floor pan modification.
63 Z06
Old 08-25-2006, 11:31 AM
Mean 69 Mean 69 is offline
Steve's t56 install is not a typical one due to the frame he is using, the floorpan needed to be modified anyway due to the motor placement, at least I am 99% certain that is the case.
Mark
Old 08-31-2006, 02:15 PM
Silver69Camaro Silver69Camaro is offline
Talking
Mike
Ahem...well...wait a couple months...
Oops, did I say that?
Old 08-31-2006, 04:23 PM
TBART70 TBART70 is offline
now you come out with it, It would have gone nicely with my tri-4bar set up.
oh well, too late now.
