Old 10-26-2014, 09:20 PM
snappytravis's Avatar
snappytravis snappytravis is offline
I am not sure what you mean by the factory one, it .mounts in front of ac condenser. It is pretty good sized I think bigger that what you would see in a ctsv caddilac. I ended up using a pump from lingenfelter for mine and purchasing several hoses with 90 degree bends worked pretty good.
Old 10-28-2014, 03:08 PM
Yes I meant Caddy or ZL1. I guess I didn't articulate my question very well
Old 10-28-2014, 04:32 PM
I thought that was what you meant, I think they may be a tad bit bigger, Just curious how much is a zl1 or Cadillac exchanger?
Old 10-28-2014, 04:35 PM
Default afco zl1 heat exhanger
http://www.phastekperformance.com/20...nger-80283.htm
I think this style is not as tall but thicker. I like the fans,, have to build some brackets to mount. The cr racing on bolts together pretty good.
Old 10-28-2014, 11:01 PM
Yes the C&R looks like a nice easy set up to use. I had just seen that advertisement you posted earlier tonight for the CTS V
Old 10-29-2014, 03:27 AM
steery's Avatar
steery steery is offline
I've got one of these for my 69 Camaro LSA conversion. Won't be installed for a few weeks though.
Old 12-05-2014, 05:48 AM
cwylie cwylie is offline
Anyone up and running with one of these yet?
Old 12-05-2014, 04:15 PM
MattG's Avatar
MattG MattG is offline
I've had mine running for 4 months now and it does a great job. My tuner says it controls inlet temps much better than the stock Magnuson heat exchanger. He was impressed to say the least!
'69 Camaro Coupe, Full Ridetech stage 3 suspension, moser wavetrac 12bolt, Forgelines, Ls3 Heads/Cam,T56 Magnum. Built by me and tuned by Ed!
'69 'Vert Camaro: DSE Sub-Frame, DSE Mini-Tub, DSE Four-Link w/9inch. LME LS7 427, T56. Tuned by Ed Hutchings, :SOLD!
Old 12-06-2014, 02:25 PM
Do you have the part number for that vintage air condenser by chance?
Old 12-06-2014, 08:33 PM
Does anyone have pictures of one of these going in or installed? sure would appreciate seeing them..
