Old 11-04-2014, 06:00 AM
supremeefi supremeefi is offline
[QUOTE=PTAddict;578145]I have no experience with any of the above, although I've researched a lot and plan to add a Harrop system in my car in the next couple of years.
(ITBs present quite different challenges to the ECU in low throttle situations).
Correct. So make sure you get an ECM that will allow you to change cyl to cyl fuel trim at not only idle but other areas of the rpm range. There are only a few that allow you to do that.
Biggest advantage of a true ITB in a streetable application is the ability to use a dramatically larger cam (specifically, larger in the sense of more overlap) while still maintaining idle quality and lower RPM drivability. That's because the close proximity of the throttle blades to the intake valves creates a much smaller total intake volume that is under vacuum, and therefore a smaller volume of exhaust reversion during overlap.
That's not the only reason. You now have no dirty air, all throats are isolated from the exhaust reversion from other cylinders.
Also, an ITB is typically easy to "tune" for optimal effective runner length and thus maximum peak torque RPM.
[QUOTE]
Hope this helps.
Mark
Engine builder and tuner.
Old 11-08-2014, 03:02 PM
OVRKILL's Avatar
OVRKILL OVRKILL is offline
PTAddict prett much touched on the highlights.
I run a Kinsler on my LS based 460. Big cubes, huge heads, any yes, a big hyd cam 260/270 .680/.680 @ 113. Idles like a 383 at 850rpm.....WOT however is a different story.
If set up properly in runner/blade balance, you shouldn't need a ECU that tunes cyl to cyl....don't get me wrong, it would be nice, but necessary.
Don't think you can go wrong with either of them, but it would solely depend on your build and want you want out of it.
Soooooo.....what are we building? Street, show, Autox? Considered selling my set-up if you're interested....heads half to go with, btw.
'01SS - RHS 460
Fikse / MWC / Kinsler / Mast
Enough torque to buckle pavement!
"Went right past silly and all the way to stupid..." - Shawn Miller
Old 11-09-2014, 05:00 PM
PTAddict PTAddict is offline
Hope this helps.
Not really sure why cylinder to cylinder fuel trim would be more important in an ITB setup. It is actually easier to make each cylinder "see" the same intake tract in a properly designed ITB setup than in a conventional common plenum intake. Adjusting the individual throttle blades to be consistent is obviously very important, of course.
I have a slightly different point of view on your dirty air comment - I can easily envision a design that has big long runners with throttle blades at the very ends which will create just as much exhaust reversion as a common plenum intake. And most "street" intakes have some common vacuum channel as well. But it really isn't worth arguing - in practice ITB intakes suffer much less from exhaust reversion with big cams than conventional intakes do, and that's all people need to know to understand the advantages.
Latest car: https://lateral-g.net/members/borduin/
EFI Tuner for: http://www.modernclassicsauto.com
Old 11-09-2014, 05:12 PM
Correct but I've done a few Hilborn systems that had blade problems on a couple of throats. Being able to change cyl to cyl trim kept it from popping at idle.
If they're isolated then they don't share the others dirty air at the wrong time.
I've done a few where they had tunnel rams or other common plenum intakes first. Idle rpm's ranged from 1100-1400 rpm's and were rough no matter what. Once they got a properly tuned true isolated IR intake all of them idled at 800 and where as smooth as silk. Not sure what else it could be, you?
Mark
Old 11-09-2014, 05:34 PM
Not disagreeing with your empirical observations, just your analysis. I should just let this go, but the pedantic engineer in me comes out The rest of you, feel free to whack us on the head.
Let's do the thought experiment. Is it possible to create a 1 cylinder engine that idles like crap with a big cam? Absolutely. Just put a big enough intake plenum after the throttle body, which can accumulate enough exhaust reversion to create the gagging effect that is lumpy cam idle. No adjacent cylinders needed But in practice with a 1 cylinder engine, chances are the throttle blade is close to the intake valve, and the volume under vacuum when the overlap cycle commences is therefore very small. So the amount of reversion is correspondingly low. An ITB engine is just eight one cylinder engines.
