Old 11-09-2014, 08:42 PM
carbuff's Avatar
carbuff carbuff is offline
Apologies if it's already been mentioned, but do you happen to have the dimensions of that SRX fan? I'm wondering how well it would fit a 'normal' sized radiator which drops into most of our cars...
Thanx!
Old 11-10-2014, 05:36 AM
samckitt's Avatar
samckitt samckitt is offline
Where are you buying this thing? I looked up the P/N & price ranged from the upper $500 to over $700.
Scot
86 Monte SS
LS2/T56 Magnum
Old 11-10-2014, 10:39 AM
PTAddict PTAddict is offline
Thanx!
I don't have the dimensions. But Stielow also used this fan on Red Devil and Mayhem, which both had more conventional radiator packaging ...
Latest car: https://lateral-g.net/members/borduin/
EFI Tuner for: http://www.modernclassicsauto.com
Old 11-11-2014, 06:43 AM
mikels mikels is offline
Shroud is 609 mm wide x 585 mm tall ( 24x23 inches)
Fan itself is not much smaller.....
Old 12-22-2014, 05:08 PM
samckitt's Avatar
So i gave these instructions to a friend to wire up the Vette PWM module. I told him to use pin J3-64 as the signal wire. He says it doesnt work and used J3-49 instead & it worked. What's up? Which pin have you guys used?
Thakns
Scot
86 Monte SS
LS2/T56 Magnum
Old 12-23-2014, 05:08 PM
Thakns
J3-49 is correct for E67 PWM fan output control. (assuming you have also changed calibrations for PWM fan control)
Dave
Old 12-24-2014, 08:34 PM
samckitt's Avatar
Thanks Dave.
Plugged it all in tonight to test, and after a few small bugs, it works! Its cool. No spike in amp draw, fan starts up slow, runs at a lower speed until you t gets hotter then runs faster. Cool.
I'm still looking for the real Bette connector and f anyone finds a source. I just used individual spade connectors.
Scot
86 Monte SS
LS2/T56 Magnum
Old 12-26-2014, 08:46 PM
andrewb70's Avatar
Scot,
What fans are you using?
Also, does anyone have the dimensions of the C6 fan pn 15819952 ?
Andrew
Old 03-27-2015, 01:10 PM
dontlifttoshift's Avatar
To anyone that has an SRX fan, can you measure the blade itself for me? Using the eyecrometer it looks like the fan itself is 20" or more but I would like to have an actual measurement.
Thanks!
Donny
Old 03-28-2015, 11:11 AM
samckitt's Avatar
Has anyone found a decent price for the SRX fan? What prices are you finding?
Scot
86 Monte SS
LS2/T56 Magnum
