Old 11-11-2014, 09:06 PM
Jr's Avatar
Jr Jr is offline
Roadster Shop Malious Chevelle
Marty,
What kind of transmission controller is this?
Also, Great pictures!
Old 11-11-2014, 09:36 PM
zz430droptop67rs's Avatar
zz430droptop67rs zz430droptop67rs is offline
Cool
Fantastic job with the pics!
No doubt the best I've seen from Sema.
I thought the Ring Bros Recoil Chevelle was out of this world.
I was also stunned by the Roadster Shop cars, especially the Malious Chevelle...wow.
Old 11-12-2014, 08:30 AM
Roadster Shop's Avatar
Supporting Vendor
RoadsterShop.com
Originally Posted by Jr View Post
Marty,
It is a PCS (Powertrain Control Solutions) push button shifter for the 6L90 trans. I beleive it works with 4L60 and 4L80 transmissions as well as a few others.
www.roadstershop.com
Old 11-12-2014, 08:32 AM
Supporting Vendor
RoadsterShop.com
Marty, thanks for posting all the pics of our builds and the rest of the cool stuff at SEMA.
Old 11-12-2014, 09:02 AM
syborg tt's Avatar
Your welcome.
marty-mj
Old 11-12-2014, 09:05 AM
syborg tt's Avatar
Scotts Hot Rods Good Guys Give Away Truck
and the 90 Day Suburban
marty-mj
Old 11-12-2014, 09:47 AM
Che70velle's Avatar
Thanks Marty! Great shots, and camera work. SEMA is on my bucket list!
Thanks Dad!!
Old 11-12-2014, 09:53 AM
hifi875's Avatar
hifi875 hifi875 is offline
mind blowing to say the least. Between these guys and Ringbrothers are the most highly detailed outside the box builders.
69 camaro
03 z06
90 mustang coupe
1950 international l110
1993 mustang gt
Old 11-12-2014, 09:58 AM
Evan Iroc-Z Evan Iroc-Z is offline
Roadster Shop,
Did you use the hardware from the Corvette to make this? I want to streamline my doors, but don't really want to use door poppers and the Corvette hardware is what I was thinking of using.
'89 IROC-Z Turbo 3.8 5SPD
LS1 Brakes|Wilwood Prop Valve|LS1 Master Cylinder|Aluminum Driveshaft|LS1 3.42 Rearend|Adj PHB|Adj LCA|LCARB|Koni Struts|Koni Shocks|Adj Caster/Camber Plates|STB|10 Spoke SS Wheels|PHB Relo Kit|Adj TA|SFC|ARAP Based Prom|B&M Short Shifter|Underdrive Pullies|SMOG!|AIR!|Rag Joint!|Magnaflow|Ported Plenum|Misc Stuff
Old 11-12-2014, 11:00 AM
syborg tt's Avatar
As some of you may know I am a big fan of SLP/Roush Racing in fact my next engine in the 70 will be from SLP.
for you guys with 5th Gens they offer a great header
The Gas Monkey Garage Pick Up was also in there Tent
This is for the Ford Guys out there
Can you guys guess what this is.
It's the new 4 cyl Mustang and it's 280 hp. If your old enough to remember the Mustang SVO from years ago this will excite you to.
marty-mj
