well this is turning into rust monkey more then thunder monkey, found more rust last night along the whole bottom of the door, it was just packed with filler. at this point it looks like I will be replacing almost all the lower sheet metal on a car that was supposed to have been repaired already. all this gets in the way of the fun stuff but I thought I would at least post up some progress (or lack there of)
Again not much progress, trying to get time to work on this car is like pulling teeth, I have 1 mini tub done and started on the other one last night nothing special just home built tubs, when I have them all cleaned up I will post some pics.
Wow haven't posted in a while. Some things have been done. The mini tubs is finished the sub frames is back in and the paint stripped and body work started. I have the 9" cut down and the torque arm install started. I am hoping to get the power train back in soon as well.
The Following User Says Thank You to aidanfancystang For This Useful Post:
