Old 11-29-2014, 05:16 AM
Rick D's Avatar
Rick D Rick D is offline
Originally Posted by mach1stang View Post
Hey guys,
Just asking a general question here, but realistically which is pound for pound dollar for dollar better? I know IRS is ultimately better. But in a "retro-fit" application which is better? I'm not discrediting roadster shop or art morrison by any means (I'm a huge fan of both) but is the upwatherds of $10k really better than a well engineered 3 link or like wise solid axle set up? And on the same lets use a cobra IRS set up for example. Is the added weight (just assuming, IDK the exact weights of both) of packaging this system really worth it? What's you guys take?
As I said sorry for such a general and vague question but I'm just thinking out loud and looking for opinions.
Kody
Kody, first I think you are off a bit on that $10K?? I think the A/M unit is almost $12K just for the unit and then if you can't install it yourself you have another $6-8K in labor to install it. Now again you will close to that to install most of the 3-4 link setups as well so more of a wash on the labor end.
As for the Roadster Shop setup your not just buying their IRS your buying a complete chassis but if you start adding up all the cost of ALL of your suspension its not that far off with the added cost of labor compared to installing the RS frame.
Now as far as the rest I have know idea but as most would say, what are your goals? Have fun look cool, or are you looking to be at the front of the pack?
I know your just kicking around the question but to think about for sure, but great topic for sure, especially with all the opinions we have today from a lot of great company's making awesome products!!
Rick
Old 11-29-2014, 07:11 AM
mach1stang's Avatar
mach1stang mach1stang is offline
Originally Posted by David Pozzi View Post
A Ford 9" with no floater and 14" rotors, 6 piston calipers weighs 195 lbs.
A Ford 9" with floater and 14" rotors and 6 piston calipers weighs 220 lbs.
To compare to the Morrison, you would need to know the weight of the shock mount bar, panhard bar, brackets, and 3 link equipment.
According to Morrison, their IRS is 30-40 lbs heavier total than a Ford 9" with suspension, but it has an even larger ring gear & is stronger. The added weight is low and to the rear which is the best place to add it if you have to add weight. The un-sprung weight drops from 150 lbs per wheel to 80 lbs assuming a 50 lb wheel and tire.
In terms of ride, IRS wins hands down, it's way way smoother riding & you will enjoy driving the car so much more on the street, it isn't funny.
In terms of autocross times, IRS will beat a stick axle with equal tuning time invested. How much? I don't know if it's a second faster, but somewhere close to that.
How much better on a road course? I don't know, but if it's a bumpy track the IRS will be faster, since lap times will be longer on a track, I think easily a second faster, maybe more, but I'm guessing. You will feel more confident going over rough sections of the track.
For a car to drag race, the stick axle probably has an edge in theory, more anti-squat could be used, but there are plenty of late model Corvettes doing pretty well at the drags.
David you bring up a very good point that I didn't even consider in unsprung weight on the tires. I didn't even think of that! And also a lot of good input.
And I didn't know that the IRS was that light. I know a 9" can be a hefty chunk of weight.
David I know you guys have the A/M IRS in Marry's car is there any potential limits on rear tire size with the A/M rear clip?
Rick I know I came in a little low on the price, I just pulled a bare RS clip with no options and that was the price so I just threw that one up there lol.
As far as install, I'm building my whole chassis myself and plan on just buying the rear suspension as a "clip" doing it myself so I'm only looking at the parts prices.
Also what is every body's thoughts on a C6 IRS swap and using the trans axle?
Kody Willis
1969 mustang fastback - Lots of secret surprises to keep under wraps.
2012 boss 302 - BMR lower control arms, relocation brackets and pan hard bar, cortex racing coilovers, enkei 18x10.5's front and rear with 315/30/18's, offroad x pipe, lethal performance over axel pipes, SLP loudmouths.
"Your boss's exhaust when you floor it sounds like Jesus stepped on a lego in the middle of the night while going to the bathroom!"
Old 11-29-2014, 10:29 AM
DETON8R's Avatar
DETON8R DETON8R is offline
Wow, building an IRS yourself. Quite an undertaking, your going to learn a whole bunch.
There are a few cars that have been built with C4 corvette rears. As long as you plan to use the stock hub to hub width it is a pretty easy swap, just go with coil-over shocks instead of the transverse spring. Stay away from narrowing the rear width too much, as other issues start to crop up and need to be resolved.
Look for the Beach Cruiser first gen Camaro and the P1800 on this site. Full custom installs, using much of the factory parts with custom install mods to fit the build.
https://lateral-g.net/forums/show...ighlight=p1800
https://lateral-g.net/forums/show...ghlight=camaro
Regarding the C5/C6 rear end and transaxle, that setup tends to blow out the back seat of most cars. There is one build on this site (1960's vintage XK120 Jaguar) where they mounted the C5/C6 Vette IRS suspension and brakes on narrow frame rails, and are using a 5th gen Camaro gear case, with modified torque tubes. https://lateral-g.net/forums/show...ghlight=jaguar
Hot Rod Magazine did a comparison of systems in existence a few years ago. It gives some good points of consideration when thinking about an IRS swap, especially limitations of the different set ups. http://www.hotrod.com/how-to/chassis...or-musclecars/
If you are looking for an outright swap with a complete rear, there is a first gen Camaro that is using a Nissan 350Z rear end (build thread is on protouring.com), lots of other cars and trucks using 1990's Ford Thunderbird IRS, and I've even seen a 69 Camaro that has an IRS from 7-series BMW, with cantilever shock set up. http://pacificfabrication.com/barrys-camaro
Got your work cut out for you. Just picking the type of IRS is a chore by itself.
DETONATOR - 69 Camaro RS
Old 11-30-2014, 09:21 AM
David Pozzi's Avatar
No limits on tire width.
If your horsepower will be high, the selection gets more limited. The C4 uses the Dana 44, which is good, but I don't know if it will handle 600hp. Newman offers a beefed up aluminum case for them. The 8.8 is probably pretty strong.
http://www.PozziRacing.com
Old 11-30-2014, 10:34 AM
mach1stang's Avatar
At this point I'm really leaning towards the C6 transaxle and IRS to help move some weight to the rear and because I know it can hold the power it's also almost a perfect match width wise. I'm only looking to make at the most 650-700hp.
Kody Willis
Old 11-30-2014, 03:00 PM
Gm takes special care to not induce wheel hop, so if you can do that, it may work. How would you deal with the torque tube input shaft?
Old 11-30-2014, 05:04 PM
BigJoe BigJoe is offline
very interesting thread, subscribed.
Aerodynamics are for people who can’t build engines. – Enzo Ferrari
- 64 Chevy C10 SWB- 440 BBC, Pro touring build in progress SLOWLY
- 71 Bronco- my dirt monkey and current focus
The military doesn't pay nearly what it should
http://someminorassemblyrequired.blogspot.com
