Old 12-04-2014, 07:17 PM
dontlifttoshift's Avatar
Would you mind posting a pic of your evaporator coil? Is it integrated with the heater core and if so why did you choose that design?
Donny
Old 01-06-2015, 11:34 AM
RPitts's Avatar
RPitts RPitts is offline
I just bought 2 bulk heads from Restomod great quality! I am in the market for two units one for a 68 and other for 69 Camaro. I would love to see some hose routing pic's of both Vintage and Restomod. I am also looking for ease of evap mounting due to both cars having smoothed fire walls. Any info would be great!
Rob
Old 01-06-2015, 03:06 PM
sleepertime's Avatar
sleepertime sleepertime is offline
Post Pics of my vintage air install on 1969 camaro...
I have the vintage air setup, If you look starting at post #47 you can see how I modified my factory brackets and added some garage made aluminum brackets. I have the smooth firewall.The bolts are thru the inside cowl, not on the outer firewall. It is rock solid when bolted tight.
My build BRNAGN 1969 camaro SS
