Old 12-06-2014, 08:33 PM
Does anyone have pictures of one of these going in or installed? sure would appreciate seeing them..
Old 12-07-2014, 10:23 AM
chassis crafters's Avatar
chassis crafters chassis crafters is offline
hey guys we installed this same unit in the 69 lsa Camaro we done for a customer. and its got to be one of the best pieces we have installed to date .it fits great and accepts vintage air .we use phil cook for are salesman great guy. just ordered one for the 63 vette we are doing with a LSA
Old 12-08-2014, 07:48 PM
cwylie cwylie is offline
What have you all used for a reservoir on these?
Old 12-08-2014, 08:15 PM
snappytravis's Avatar
snappytravis snappytravis is offline
That's the tricky part, I looked and looked, I think a person could use a reservoir out of a magnuson kit for 5th gen Camaro. It is small and mounts to the firewall, I however figured that the more capacity I had for coolant the better it may cool.
So I looked up canton racing and ordered a blem tank( small weld splatter on the aluminum) It is a batter box style tank for a mustang. I built a frame much like a battery box out of 1 inch angle. I mounted it to the radiator support and to the inner fender on the passengers side.
I then went and bought several different length 90 degree bend hoses, say 4 inches, then 14 or 16 or 18. They run down between the tank and radiator and under the radiator support to the front of vehicle where the intercooler pump is mounted. then out of pump into the heat exchanger.
I ordered a pump from lingenfelter it had the harness and everything with it.
Good luck, Hope I helped you out,
https://www.cantonracingproducts.com...5-10-MUSTANGS/
look up gates 28474 hose. You can get a different ones with various lengths, then cut to fit your setup.
Old 12-15-2014, 03:34 PM
How did you all mount the bottom bracket? I noticed they spacers and bolts included with the kit and I assume they want you to drill through the core support but there were no instructions.
Old 12-15-2014, 08:09 PM
I believe I did and ran the bolts through the back side. Spacers just keep from crushing radiator support. Hope this helps
Old 12-27-2014, 09:26 PM
Travis which pump did you get from Lingenfelter? I just got the Stewart EMP pump to use in my car, and last week I called C&R to talk about the Heat exchanger.
