Old 12-15-2014, 04:34 PM
cwylie cwylie is offline
How did you all mount the bottom bracket? I noticed they spacers and bolts included with the kit and I assume they want you to drill through the core support but there were no instructions.
Old 12-15-2014, 09:09 PM
snappytravis's Avatar
snappytravis snappytravis is offline
I believe I did and ran the bolts through the back side. Spacers just keep from crushing radiator support. Hope this helps
Old 12-27-2014, 10:26 PM
Travis which pump did you get from Lingenfelter? I just got the Stewart EMP pump to use in my car, and last week I called C&R to talk about the Heat exchanger.
Old 12-28-2014, 08:36 AM
This one, I mounted it on the bottom of the rad support on passengers side. I used one of the bolts that runs through the bottom of the heat exchanger and mounted the pump horizontal with the band clamp that comes with it. Then ran my wiring down the pas inner fender. Then 5 miles of hoses! If you need pictures pm me you cell and I can text you a few next time I go to the shop. I know they make higher volume pumps I just didn't think I really needed one with the volume of coolant I have in my reservoir and the size of the heat exchanger.
http://www.lingenfelter.com/mm5/merc...gh=#.VKAi1B0MA
Old 12-28-2014, 01:16 PM
I grabbed the one I have because I saw it on E Bay cheap and figured I needed one anyway.
Old 01-12-2015, 10:37 PM
Well men my Heat Exchanger came in today. Very Nice piece.
Old 01-13-2015, 08:01 AM
Hey I noticed the hood latch clears the heat exhanger but hits the top lip on the a/c condenser. How did you all resolve this? Does cutting the lip off the condenser give you enough clearance? Should I worry about messing up the condenser if I cut that lip off?
