Old 12-11-2014, 01:48 PM
Sieg's Avatar
Sieg Sieg is offline
Originally Posted by DOOM View Post
Not you to now!!
I thought about that Greg but I have to have them working the way they were intended. Its just me.
I'd be the same way..........a friend tried to talk me into doing the RS conversion on my car when I first got it 20+ years ago and I looked at the system in the factory build manual and started counting pieces and said to myself no f'n way I'll go insane. I'm sure the DSE system is much easier but.....
Good Luck!
Old 12-11-2014, 04:06 PM
DOOM's Avatar
DOOM DOOM is offline
Originally Posted by frankv11 View Post
its a pain to get them right but its doable.
if you make the two wholes on the core support bigger it gives you some much needed wiggle room . you'll be surprised how much alignment gets better with just a slight movement. once you get them where you want them. place a washer (with correct ID )to cover enlarged whole, trace perimeter and cut it out, weld washer of correct gauge to match core support and you'll have a nice pretty finish with correct whole location.
also playing with shims ( adding / subtracting ) on door shaft I also used a washer / shim on the core support bolts between core and housing to tilt up or down.
its going to take some pulling and pushing on the rest of it.
hope this helps
Oh I'm a master with the shims thats for sure Frank!! I did exactly what you said and it does help a ton. What worries me the most is Troy said every time he took something off the car it never went back the same. These assemblies mount to the core support witch mount to the sub frame so I'm trying to come up with way to,PIN/MARK everything that the assemblies mount to and hopefully it will help when they go back together
Good Luck!
Troy tried once to talk me out of it but did I listen. It's always been one of my favorite front ends since I can remember there was no way it wasn't going on my car.
Mario
USCOLLISION
Old 12-12-2014, 11:35 PM
frankv11's Avatar
frankv11 frankv11 is offline
[QUOTE=DOOM;585119]Oh I'm a master with the shims thats for sure Frank!! I did exactly what you said and it does help a ton. What worries me the most is Troy said every time he took something off the car it never went back the same. These assemblies mount to the core support witch mount to the sub frame so I'm trying to come up with way to,PIN/MARK everything that the assemblies mount to and hopefully it will help when they go back together
I was pretty sure you would be the man with shim/ adjustments , being a body man by trade. I agree with you on the car going back together. It can move on you quite a bit. I'm also going to be doing some kind of marking or pin for the same reason. For my self It helps that I have personally broken it and built it some many times that kind of know the car.
Hope you make it out to west coast for some events. would like to see that thing in person.
Old 12-16-2014, 06:23 AM
RCC RCC is offline
WOW WHAT A BUILD!!!! can't wait to see with paint and interior is there a rendering somewhere ?
Old 12-16-2014, 06:34 AM
DOOM's Avatar
First rendering
Mario
USCOLLISION
Old 12-16-2014, 07:30 AM
RCC RCC is offline
I would say it changed some FOR THE BETTER I like the tasteful mods
BBT done some awesome work I sat in frt of lap top last nite just couldn't stop reading and looking very impressed
Old 12-16-2014, 07:41 AM
RCC RCC is offline
have you looked into these R/S headlight motors I've only done the 67 ones
and liked them the DSE just goes into Failsafe a little to easy
http://retro-electro.net/
Old 12-16-2014, 11:39 AM
96z28ss's Avatar
96z28ss 96z28ss is offline
How long did it take to find that 10 year old rendering? Come one we want to see some real pics!
1969 Camaro LS2/T56 D1SC
www.automotivedesigneng.com
Old 12-16-2014, 04:34 PM
tones2SS's Avatar
tones2SS tones2SS is offline
LOL
I will say that rendering does look really mean though.
Old 12-16-2014, 07:17 PM
tmadden's Avatar
tmadden tmadden is offline
WOW. Nasty rendering
