Old 12-17-2014, 08:31 AM
71RS/SS396's Avatar
The LSA blower manifold will not work with 243 heads. The LSA has square port heads, the 243 heads are cathedral ports.
Old 12-18-2014, 09:53 AM
badazz81z28 badazz81z28 is offline
Not only that, you can't put the Rect port heads on a small bore engine. OP, you might want to re-evaluate the build.
Old 12-28-2014, 10:21 AM
71455Formula's Avatar
71455Formula 71455Formula is offline
I saw someone has the rectangle port heads for the small bore motors. Can't remember who though.
1971 LS5 Firebird Formula with a 6 speed(Finally drivable)
2013 GMC Sierra(sold)
2000 Formula Ws6 6 speed(miss her!)
Old 12-28-2014, 11:00 AM
71RS/SS396's Avatar
Mast did have some but I don't believe they make them anymore.
Old 12-28-2014, 04:37 PM
Jr's Avatar
Jr Jr is offline
I read on another forum that you can fit rectangle port heads on a small bore motor if you run smaller intake valves. Understand that I read that somewhere, I have no proof that it works.
Old 12-29-2014, 01:50 PM
Where would the benefit be? Massive flowing heads with little valves. You couldn't take advantage of them. I would suggest a killer set of LS1/LS2 heads.
Old 12-29-2014, 03:40 PM
Found them.
http://www.racingheadservice.com/rhs...r-ls1-ls2html/
