Old 12-18-2014, 01:12 PM
69greyghost 69greyghost is offline
Originally Posted by im4u2nvss View Post
There are many C5 boosters on ebay at this time.
Ok so after talking to my buddy he suggested that I get an aftermarket booster that will work now and when I use the gen 4 front and rear disk later. The reason I need a new booster is the stock one is so large it is in the way of my coil packs, not to mention I want something that looks more modern. Do you guys know of a booster that doesnt need any brackets or mods, that is inexpensive, not that large, and that looks fairly moderns/ not shiny? Also it needs to work with my current brakes and work when I get gen 4 disk put all the way around. I know this is a tall order and kind of tedious but thats kinda what Im looking for. Do I have any optons or is the c5 booster the way to go?Thanks again guys for your help in advance.
Old 12-18-2014, 07:23 PM
rickpaw rickpaw is offline
Or you can run the tuff stuff booster part number 2229NC
http://m.summitracing.com/parts/tff-2229nc
Works perfectly with the DSE reduced angle bracket
http://m.summitracing.com/parts/dsr-050302
You will also need the pedal clevis kit
http://m.summitracing.com/parts/sum-760125
What Vince posted above. You can also get the black version. I have used all items Vince posted in my 67 Firebird. works great. I have C6 brake front/02 F-body rear.
Tu Ho
Old 12-18-2014, 07:44 PM
That booster says it's 9 inches. I think that's the same size as what I have. I wanted something like 7 or 8 inches. How big is the c5 one? Maybe mines is 10 or 11.
Old 12-18-2014, 11:21 PM
that is the same dims as a Corvette one only difference is the push rod.
Old 01-03-2015, 08:23 PM
Pete68's Avatar
Pete68 Pete68 is offline
I bought a C5 booster for my first gen on ebay for 150. Love it and relatively easy to mount. Had to cut the rod and use an early 70s Nova bracket to mount the booster to the firewall. Easy
1968 Camaro
2003 Boxster S
http://www.cardomain.com/ride/2543199
