Old 11-19-2014, 08:23 AM
LXSS350 LXSS350 is offline
Default ZR1 LS9 Flywheel
Anyone know an accurate pedestal mounting height for the OEM LS9 Flywheel as measured from the flywheels clutch plate face? Running the ZR1 OEM clutch kit and I am machining up a 6061 T6 flywheel for a non chev/gm engine.
Old 12-10-2014, 06:25 AM
Now sorted.
FYI for those who are looking at doing an LS9/LS/LSX/LSA/ and even the new LT1 (gen5) conversion and want to use the excellent oem ZF-Sachs twin-plate clutch kit from the C6 ZR1 - some good news. I talked to Dan @ Fidanza and they will be offering a 6061 T6 Aluminum Flywheel in 6 bolt, 8 bolt and 9 bolt versions for the multitude of common GM engine swaps.
Old 12-21-2014, 11:00 AM
andrewb70's Avatar
Originally Posted by LXSS350 View Post
Now sorted.
Any time frame on the Fidanza flywheels?
Andrew
Old 12-22-2014, 03:49 AM
Smile
Andrew
Doing them now so be in stock by mid Jan.
Old 12-23-2014, 07:59 AM
cwylie cwylie is offline
Is the CTS-V and ZR1 clutch the same?
Old 12-27-2014, 09:18 AM
andrewb70's Avatar
No. They are both dual disk, but the LSA clutch is smaller in diameter and uses a dual mass flywheel, while the ZR1 uses a single mass flywheel.
Andrew
Old 12-28-2014, 10:25 AM
Smile
Vastly different the ZR1 is made by ZF-Sachs and can handle around 850ft-lbs.
ZR1
CTS-V
Old 01-08-2015, 12:10 PM
Any info on when the Fadanza flywheel will be available?
Old 01-08-2015, 03:37 PM
So they are only selling the flywheel through Katech which wants $850 bucks for it.
Old 01-23-2015, 10:19 AM
No nothing to do with Katech or $850.
I don't have the part numbers off the top of my head but they are selling them via their dealers and website. Best to give Dan Jenkins at Fidanza a call on 440-259-5656 ext. 102
They are doing a run of them now.
