Old 01-06-2015, 11:29 AM
Originally Posted by raustinss View Post
Typically when you increase the spline count you will increase the contact area. Think of a 4000 lb car on 4 275 tires verses 4 205 tires...which one has more contact area to apply to the pavement. I know not the best example but you get the idea. Now having said that the magnum uses a much beefier shaft and larger gear face while still using the way more popular 26 spline input shaft. Allowing the aftermarket to continue with their current product lineups
true, having 1.5 teeth in the place of 1 tooth provides more gear surface contact. Making it much more resistant to clashing and shearing.
Old 01-26-2015, 11:26 PM
gnx7's Avatar
gnx7 gnx7 is offline
The mainshaft is the weaklink once you put in a steel 3/4 shift fork. If you launch hard on slicks beyond 600rwhp you are on borrowed time.
That being said a customer of mine never broke a stg2 T56 I built with basic upgrades. Mellow launch and 9.20s@162mph in a 3000lb car. Gts76 Turbo ls3 rx7.
Supposedly at 3500lbs the Mainshaft (output shaft) limit for repeated abuse is about 600rwhp/tq on slicks. An upgraded viper 30 spline shaft is reliable to about 900rwtq... Beyond that the gears are the weak link. Especially 5th in top speed high hp racing.
There are a bunch of twin turbo Vipers running stock T56s into the 8s. How long they last is a roll of the dice.
If you have the $.... A T56 magnum is a very nice shifting transmission. I'm putting over 1100rwhp thru mine.
Old 01-06-2015, 06:45 AM
MeanMike MeanMike is offline
Originally Posted by badazz81z28 View Post
I don't see how even a 30 or 32 spline makes the transmission stronger. The input shaft is still 1-1/8" and 26 splines. Youre only as strong as your weakest link. You will bust teeth off the gears before you shear a input or main shaft. The T56 Magnum's strength over OEM transmissions is mainly the gears.
Edit....I found this http://www.moderndriveline.com/Techn...s_improved.htm
Because the output shaft sees mulitple times the torque the input shaft sees. If you have a 2.66 first gear and 500 ft.lb. of torque at the flywheel, you'll have 500 ft.lb. on the input and 1330 ft. lb. of torque at the output shaft.
The T56 magnums strength comes from almost everything in the trans, not one single part.
Old 01-06-2015, 08:07 AM
Stovebolter's Avatar
Stovebolter Stovebolter is offline
Default No Magnum parts available?
Does no-one find it disconcerting that you or I can't order individual parts for the Magnum? That scares me away from the Magnum. I've been digging all day. D&D sells a few parts but not many.
I'm curious to know what is needed to convert a T56 to a T56 Magnum if I already have a tail house. Already know I need the mainshaft, but albeit the parts on that shaft are all different due to larger diameter.
468 BBC, TH400, Moser 9" floater, True Forged Competitions 18x9.5 18x12, Kore 3 C6 ZO6 calipers 14" & 13" rotors, Ride Tech True Turn, Ride Tech Air TQ's, Torque Arm with Watts link, Moser CT Full Floater 9" with locker.
Old 01-06-2015, 10:52 AM
andrewb70's Avatar
I am not sure that a regular T56 can be turned into a Tr6060 (Magnum). The Magnum uses a different case, has gears are wider and the synchro design is different.
If you want a high HP T56, look at the G-Force internals.
http://www.gforcetransmissions.com/tran_gt-56.asp
Andrew
