Old 01-11-2015, 08:49 PM
Che70velle's Avatar
I will be all over this when late summer/ early fall arrives. Exactly what I've been looking for.
Jay, what material will you be cutting the production bracketry from?
Also, are the axles an "in stock" item at Strange, or will they be built per order, with a wait time?
Thanks Dad!!
Old 01-12-2015, 06:26 AM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Scott,
Steel Flanges are and will remain 1018, and the Aluminum Spacers from 6061. To not confuse anyone I would like to say I am just a guy in a garage with ideas/resources to make my ideas come to life. So I kinda laugh when I here the word production cuz that sounds Big . I am sharing this part (and others soon) for three reasons. One - to help offset the cost of my own set. Two - hopefully offer others with same interest another option. Three - possibly strike enough interest to actually make some
The axles are made per order and are not in stock.
Thanks, Jay
Old 01-12-2015, 06:59 AM
Rick D's Avatar
Rick D Rick D is offline
Very nice Jay, glad to see you still have the crestive juices flowing!!
Rick
Old 01-12-2015, 09:51 AM
mitch_04 mitch_04 is offline
I sure hope these are still around when I get to the point of needing them!
Old 01-12-2015, 05:58 PM
There is no time like the present! Pay the mortgage with what's left!
Old 01-12-2015, 06:41 PM
Build-It-Break-it's Avatar
Do you have pictures of everything installed on the rear end? I like the set up. If I didn't have me rear end already done this might of been the route I took.
Ahmad B
Old 01-12-2015, 07:47 PM
Her is one in the alignment fixture....
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 01-12-2015, 05:54 PM
Thanks Rick!
Old 01-18-2015, 11:09 AM
takid455 takid455 is offline
I am guessing axle will have a threaded portion on the end such to affix a nut? Wont this 'pull' on the 'C' clips and cause unwanted wear? 9" applications wont have this issue what will prevent the axle from sliding out on a 9"
Just not picturing the axle setup at the moment.
Old 01-18-2015, 11:20 AM
dontlifttoshift's Avatar
You don't use the c clips anymore, the hub would hold the axle in place then.
Donny
