Old 01-18-2015, 03:31 PM
alky alky is offline
Default Actual width not stated
Hello, need some real world info, if anyone has it. It would be most helpful.
I need the actual width of a 325/30/19 on a 19x12 rim.
Im looking at buying Nittos and I have been hearing they run on the smaller side.
If you have measurment, could you please state what brand tire.
Denny
Old 01-19-2015, 12:05 AM
spode's Avatar
spode spode is offline
Nitto Invos, 325-30-19 on 12" wheel. Roughly 13 3/16 overall and 11 7/8 tread
Old 01-19-2015, 12:09 AM
Sieg's Avatar
Sieg Sieg is offline
Scroll down to sizes and specs and click on your rim diameter: http://www.nittotire.com/passenger-t...formance-tire/
Old 01-19-2015, 12:13 AM
spode's Avatar
Well I have a couple pictures but can't seem to get them to show up.
Old 01-19-2015, 09:54 AM
Thanks,
Wow that is wider then I fugured. I was thimking 12.8 to 13" depending on brand.
Old 01-19-2015, 11:28 AM
Rod P's Avatar
Rod P Rod P is offline
1 Inch = 25.4 Millimeters
325/30/19
325(mm)/30(aspect ratio)/19(dia)
325...is the mm
325mm divided by 25.4mm = width of tire in inches. (12.795") ...
give or take for factory fudge numbers....
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 01-19-2015, 11:43 AM
spode's Avatar
Finally figured it out. Pictures added.
Old 01-22-2015, 10:22 PM
Thanks for the pics
