Old 01-19-2015, 11:24 AM
dhutton dhutton is offline
Originally Posted by Blake Foster View Post
The mounts are supposed to be up at the floor. there should be 1/8 - 3/16 gap but that is all.
Just re red the OP first post and the car is a second gen so that is probably the issue the AST Cross member shown a couple post back is a first gen X Member and the second gen has a different shape floor and the side brackets are shorter. I an thinking that is where the confusion is.
I think part of the confusion comes from DSE saying their second gen subframe uses a first gen crossmember. At least that is my understanding.
Old 01-19-2015, 04:22 PM
Blake Foster's Avatar
Humm. I know we installed our X member on a 69 with a DSE sub here in the shop.
the second gen we have not worked on, I know our ATS side mounts fo ra second gen are substantially shorter as the floor on a second gen is a lot closer at the floor. it would not surprise me if the ATS first gen X member didn't fit the second gen.
Blake Foster
www.speedtechperformance.com
Old 01-19-2015, 05:16 PM
Z06vette's Avatar
Z06vette Z06vette is offline
I have used your crossmember on several first gen cars but all had stock subframe. It was close to floor but cleared. I'm kind of at a loss what to try next. Would your 2nd gen brackets work on first gen x member? Heres a few pics. Was hard to get the camera up in there to get a good shot. The left side is with the subframe bolts tightened down all the way. Right side the is about 1/4" between body bushing & floor.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 01-20-2015, 08:09 AM
I am not sure, Great Answer right, it may be that DSE has changed the height of the subframe where the Cross member is (compared to the stock subframe) if the cross member side brackets were moved back (drill new holes) would it then fit? or ar the side brackets just too tall?
I would have to check the OAW of the second gen mounting holes (on a stock sub frame are 32" a first gen is somewhere around 30") so with out knowing the width on the DSE frame hard to answer the question. is the secondgen DSE frame the same width as the first? I would think not?
Blake Foster
Old 01-20-2015, 01:34 PM
Z06vette's Avatar
I just ordered a crossmember thru BRP. It looks to have clearance where I need it. Will test fit this weekend and report back.
69 RS LS3/T56
67 RS LS2/T56
Old 01-23-2015, 07:48 PM
Z06vette's Avatar
Well, the muscle rods crossmember does not fit either. I could have modified the frame brackets to make that part work, but the headers were right in line with the cross bar. Top 1/3rd of the opening was blocked and would only be worse if I needed to shim the tailshaft on the trans up. Next I will try the G-force and possibly the bowler. This sucks- what are you guys using for a crossmember in a first gen DSE frame??
69 RS LS3/T56
67 RS LS2/T56
Old 01-26-2015, 02:32 PM
PM SENT!
Blake Foster
Old 02-12-2015, 05:28 AM
rickpaw rickpaw is offline
Scott, here's a thought. Maybe your floor pan may have sagged over the years, if it's an original floor. My firebird has original floor pan, and the original crossmember will hit the floor on the pass side. A floor jack with a 2x4 underneath the sag fixed that.
Tu Ho
Old 01-23-2015, 08:35 PM
badazz81z28 badazz81z28 is offline
Don,
Appears to be true, The frames bolt hole spacing and frame width to accomdate the crossmember is exactly like a 1st gen. Based on the 1st gen information here, I have not even checked to see if a second gen crossmember is the same width.
Old 01-26-2015, 02:31 PM
Originally Posted by badazz81z28 View Post
Don,
second gen should be wider. both in body mounts and X member
Blake Foster
