Old 01-23-2015, 05:17 PM
badazz81z28 badazz81z28 is offline
I don't understand why you would need a bigger disc on the back. Most of the braking power come from the front wheels. If I had to choose, bigger disc on the front or just make them equal. The bigger disc and piston area on the caliper is what you want to reduce heat, reduce brake fade, increased clamping force surface area.
