Old 01-11-2015, 07:35 PM
h8rbuilt h8rbuilt is offline
Got alot done the past two days! Got motor and trans mounted in the car. Still not sure if I like the trans mount, may make a tubular once I buy a tube bender. What you Guys think? Also mocked up the suspension if anyone has any insight on setting up the c5 geometry let me know! Also started playing with sheet metal and tryin some "lightening" holes on the front frame.
Old 01-11-2015, 09:57 PM
DBasher's Avatar
DBasher DBasher is offline
Progress is looking good, keep at it! If I were you I'd get the tubing bender ASAP. Once you get comfortable you'll be making all sorts of goodies with it and want to change a bunch of stuff.....didn't someone offer to loan you one?
Old 01-12-2015, 11:25 AM
Thanks man and yeah he did but I plan on doing this as a career so I'm gonna go ahead and grab a protool mB 105
Old 01-25-2015, 03:01 PM
Well got the front end finalized minus the tie rods, sway bars, and coil overs. Got the brakes and wheel setup figured out too. Hoping to start on the rear suspension next weekend hopefully! Gonna have to fab up a spacer for the wheel as the brake caliper is touching it, shouldnt be to hard to fix though!
Old 01-26-2015, 09:36 AM
Please gusset those upper control arm mounts.
Old 01-26-2015, 10:02 AM
Ppd1979 Ppd1979 is offline
Did you make the engine crossmember, or get it from street rod garage also.
Old 01-27-2015, 10:05 AM
I plan too use a triangle gusset but do you have any other ideas that will look good?
I got from speedway. It's a modified mustang II unit.
Old 01-27-2015, 11:25 AM
No, a simple triangle will look good. To help keep it clean, you may consider trying to incorporate the upper coilover mount and gusset into one piece.
Old 05-11-2015, 11:12 PM
Any new updates?
Old 05-12-2015, 07:29 AM
DavidBoren DavidBoren is offline
Very cool project. I like the weight reduction holes in the front... They also add a crumple zone, which is a nice safety feature.
Once you get it all up and running, give Ron Sutton a call/ email. He is a member on this forum, and he will help you set up your suspension correctly.
