Go Back   Lateral-g Forums > Technical Discussions > Man Caves
Old 01-30-2015, 09:36 AM
You know you can buy a "tapered/beveled" edge for that --- would save you twisted ankles and the car would run up on it nicer.... not to mention it would be more "finished". Great solution to your issue BTW.
Old 01-30-2015, 09:48 AM
DRJDVM's '69's Avatar
Looks cool... How's the price compared to Racedeck?...
Old 01-30-2015, 12:11 PM
JKnight JKnight is offline
$139.99 for 48 sq. ft., per Costco online as of today...
So, 8 packs for a normal 2 car garage? ~400 sq ft?
Add in a couple "finishing" packs with the edges Greg mentioned at $70 a piece, it's a $1k+ job.
To answer Ned's question, looks to be about 20% cheaper than Racedeck but with a limited color palette and texture selection.
Last edited by JKnight; 01-30-2015 at 12:56 PM. Reason: don't know how big a garage is...
Old 01-30-2015, 03:06 PM
craig510's Avatar
craig510 craig510 is offline
How does that stuff hold up to weld spatter and grinding sparks?
Old 01-30-2015, 04:05 PM
It's PLASTIC..... so that's an "it all depends" answer. A little or a lot.... how much amperage - how big is the wire - you welding 6 feet or half an inch.
I had this stuff upstairs in my man room (boys room if you're name is Gwen).... and I hated cleaning it. The diamond plate surface made it hard to vacuum... and moping was out of the question... and it does get scuff marks on it pretty easily.
Don't drag or scoot a chair on it because it will make a permanent scratch.
It's great stuff - can turn an ordinary space into a cool space quickly and simply - and doesn't cost all that much - and can be taken up and moved or replaced with new pieces...
Old 01-31-2015, 03:15 AM
Sheck44's Avatar
Sheck44 Sheck44 is offline
Default Thanks
Thanks Greg, ya I know ... still working on a way to finish the outside. "canadian' Costco's do not carry the beveled edge (screwed again) so I'm looking at a few other options as I have the 3/4" ply under it.
Cheers
Steve
Old 01-31-2015, 09:52 AM
Sheck where abouts are you located
Old 01-31-2015, 01:36 PM
Sheck44's Avatar
Default Location
I'm in north Pickering , just north east of Toronto
Cheers
Steve
'Build it RIGHT the 2nd time'
69' SS X11 PRO-TOURING - SOLD
73' FJ40 LS - SOLD
1966 FJ40 R2.8 -SOLD
911 Hotrod - SOLD
2002 Gated 360
Next up - "Killer Piggy"
67' Camaro - Take-Over'
Old 02-27-2015, 03:46 AM
tigerhays's Avatar
tigerhays tigerhays is offline
Default Thanks
Thats a great idea...will look into doing that on mine!
Old 02-27-2015, 08:31 PM
Angry's Avatar
Angry Angry is offline
Go to a lumber merchant n get some lumber in 1.5H x 3 or 4" L with bevel. Paint or stain it black....
Al
1969 Camaro Pro Touring
1964 F100 patina pickup cruiser
Australia
