Go Back   Lateral-g Forums > Technical Discussions > Man Caves
Old 01-30-2015, 04:06 PM
craig510's Avatar
craig510 craig510 is offline
How does that stuff hold up to weld spatter and grinding sparks?
Old 01-30-2015, 05:05 PM
It's PLASTIC..... so that's an "it all depends" answer. A little or a lot.... how much amperage - how big is the wire - you welding 6 feet or half an inch.
I had this stuff upstairs in my man room (boys room if you're name is Gwen).... and I hated cleaning it. The diamond plate surface made it hard to vacuum... and moping was out of the question... and it does get scuff marks on it pretty easily.
Don't drag or scoot a chair on it because it will make a permanent scratch.
It's great stuff - can turn an ordinary space into a cool space quickly and simply - and doesn't cost all that much - and can be taken up and moved or replaced with new pieces...
