Old 07-17-2014, 04:27 AM
Motobrewmaster's Avatar
Motobrewmaster Motobrewmaster is offline
Have you considered Rocket Racing Booster wheels? They come in the correct sizes and back spacing. I have them on my 69 and they fit perfect with 245/40ZR18 & 275/35ZR18. They also had enough clearance for my 14" Wilwood 6 pots in front.
69 Camaro Owned since 1984.
Oh and Yes I am a Brewmaster.
Old 07-17-2014, 05:11 AM
MCMLXIX MCMLXIX is offline
Since my car is stock now but I want to upgrade later, I can run these with spacers. Then when I replace the rear I can build it with the correct width so I wouldn't need the spacer later.... I would love a DSE front clip but the cost may be more then I can afford....Not sure what a DSE front subframe will accept for wheels either...
While I like the Rocket Racing wheel, and I had a set of Coys on my Chevelle, I want something different. No deep lips. I want the concave look with spokes that come out the the outer edge. If I had big 4 or 6 piston brakes I would find a split 5 spoke the show them off....
You can get a set of those Niche Circuit rims in 18s for about $850 off ebay...
Rich
Las Vegas
1969 Camaro * in hiberation ~
Old 02-02-2015, 02:11 PM
OBeer-WAN-Kenobi's Avatar
Well,
I'm finally starting to shop in earnest for some wheels. I should have enough in my income tax return to increase my budget just a bit.
I'd like to stay under $300 per wheel.
Anyway, I've been nosing around quite a bit today and I can't seem to find anything in the proper size that's not a "vintage" style.
I'm thinking that the best bet is going to be buying some +25 to +40 offset 5x120mm wheels and using a spacer/adapter which converts to 5x120.65 AND has a thickness equal to the offset of the rim minus 6mm. I might have to machine some myself If I can't find anything close.
I think that's going to give me a huge variety in cheap choices.
Still looking for other suggestions though.
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
Old 02-02-2015, 03:53 PM
Sideshow Sideshow is offline
Forgestar. 1100 shipped.
Old 02-03-2015, 03:07 AM
Build-It-Break-it's Avatar
I was considering there rims to but looked them up and a lot of people have had quality issues and customer service issues. I guess that could be anywhere you go tho.
Ahmad B
Old 02-03-2015, 07:30 AM
Forgestar is perfectly fine. I know several people who have them and only one that had an issue has a discontinued finish (titanium). All others have been VERY good.
William
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 02-03-2015, 05:08 PM
ArisESQ ArisESQ is offline
I'd do forgestar. Best looking wheel for that price point.
Old 02-04-2015, 11:27 AM
William
Did any of you get them for a 69 Camaro?
I called today and it seems they have one for the back that would work but the front wheels they have would require a 20mm spacer. I like the wheels, I'm just hoping for a solution that fits. If I have to do spacers, I might as well go with my 5 x 120 wheel idea.
'69 RS Camaro
Old 02-04-2015, 11:55 AM
OK,
After calling forgestar directly, it seems I have to go to a 9" wheel up front to get the right offset/backspacing and not need to deal with a spacer. It's going to go towards the subframe but stay the same distance away from the outer fender. It's also only availlable in the F14 Style. Seems like a decent option though.
So, I shouldn't lose too much turning radius with a 9" wide wheel up front right? Anything else I need to worry about?
'69 RS Camaro
Old 02-04-2015, 03:13 PM
Che70velle's Avatar
Stielow just bought a set for his new/old/newish/newest project, and they look great. You won't find a nicer wheel in this price point.
Thanks Dad!!
