Old 02-04-2015, 11:49 PM
Originally Posted by Msracing89 View Post
We will be there with Dbasher and crew. Looking forward to some good times.
Cool Charger... what's it got cookin in it?
Old 02-05-2015, 08:35 AM
DBasher's Avatar
DBasher DBasher is offline
Pretty typical big block...aluminum heads, port injection, some forged internals...it's good for about 300hp
It's a street car that does well on the track, especially when put up against other street cars....
I've been wanting to do a write up on the harness bar, if that doesn't happen before the event come by and check it out, it's the coolest!
Old 02-05-2015, 09:03 AM
GrabberGT's Avatar
The ultimate form of sandbagging... When others do it for you.
Chris
Its not a Vega!!!!
Old 02-05-2015, 09:25 AM
Panteracer's Avatar
Default optima
I ran against a guy that said he and his buddies car
had a junkyard motor in it...he won all the time
They were not allowed to put subframe connectors
or weld in a cage.. they welded some posts to the
floor, ran a low bar on the cage (subframe connector's) but
had a pipe slide over the welded in pipe and ran a bolt
thru it.. so it was all bolted in.. Smokey's rules bent just a little
but legal He was pretty smart.. raced his buddies car
but had 18 muscle cars all Z/28's or big block F-bodies
Bob
Old 02-07-2015, 10:45 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
Originally Posted by RPitts View Post
Sooo with the whole Tw200 and no "R" compound what is the tire of choice? FYI NT05 are on national backorder and thinking my only chance is Michelin SS? Now I know some might not want to put that info out but if you wouldn't mind sending a PM.
Sorry car is 2013 ZL1
Thanks,
Rob
I would run Pilot Super Sports, or the oem Goodyear G2s. Hankook RS3s are good too if they come in your size, although they might only go up to 19"
Old 02-09-2015, 06:30 PM
pro71bird's Avatar
pro71bird pro71bird is offline
+1 on the Pilot Super Sports
George Dias
1972 Camaro
2002 F150 Lightning
Old 02-20-2015, 08:01 AM
Gscherer78ta's Avatar
Gscherer78ta Gscherer78ta is offline
Just registered for the TMS event. This is going to be fun!
Greg
'78 Trans Am - Y88-R LS3/T56,
Holley EFI, UMI Performance
Old 02-21-2015, 06:26 AM
GrabberGT's Avatar
Im getting pretty stoked myself. Still have lots of work to do though to have the car ready in time. I'd like to hit the SCCA event the weekend before goodguys as a shakedown event. My baby needs foreplay before she's fully charged for action.
Chris
Its not a Vega!!!!
Old 02-24-2015, 06:03 AM
I had my first shake down cruise last weekend at Lone Star with wonderful conditions... Standing water, pouring cats and dogs outside, only sprinkling inside, wipers going( at least they worked).....
Still, the car handles much better than last year with the changes I made to keep the tires fully contacting the road. I am planning on a few more events before the USCA- I hope the car has the same plan.
Greg
Old 02-24-2015, 09:09 AM
MattO MattO is offline
Crap, I forgot to buy a pass for my dad. Can I do that at the event, or do I need to go online?
"I should have just started smoking crack. Its just as addicting and WAY cheaper..." --unknown
