Old 02-13-2015, 10:38 PM
Sieg's Avatar
Sieg Sieg is offline
Originally Posted by Payton King View Post
It will pose a challenge, but you will get through it. LOL
And you will be back on the road again...
What pads are you running?
The offsets were off .394" or so which means I need to fab new spacers for the caliper brackets but that's no biggy.
I'm pretty sure the rears are Wilwood BP-20's and Tobin said those would be near ideal for balance with the Hawk HP+ pads up front. The Dynalite calipers have more clamping force than ideal for the C5 caliper up front so the pad should tame them.
Old 02-13-2015, 10:59 PM
Sieg's Avatar
Progress was slower than I'd hoped but still decent progress. Hard lines were built, drop line installed, axles in, offsets checked and need to be altered -0.394". Funeral out of town tomorrow so I'll get back on it Sunday.
Old 02-13-2015, 11:03 PM
Please stop!!
LOL
Get it??
Old 02-13-2015, 11:14 PM
Sieg's Avatar
Please stop!!
LOL
Get it??
It will have a firm pedal before it rolls.
Old 02-18-2015, 12:10 AM
Sieg's Avatar
There's light at the end of the tunnel! 2 lb. residual valve installed, backing plates located and torqued, caliper brackets shimmed, line brackets painted, lines mounted, wheel clearances verified, Moser C-clip axles are in and the differential refilled. Basically all that's left is to measure e-brake cable lengths and order and bleed the system.
I opted to shim with grade 8 washers and one stainless vs the cutting down the aluminum Wilwood spacers.
While positioning the calipers I noticed one pad didn't want to compress back into the caliper with reasonable force...........so off the calipers came again and I pulled all the pistons and seals figuring if one's questionable the other probably are too.
A little buffing with a red Scotchbrite pad and good as new.
Seals were easy to pop out with a dental pick, wiped the bores and seals clean, used a Q-tip on the seal grooves, and wiped the seal and piston with a very lite coat of WD-40 before reinstalling. Pistons now move properly in their bores.
Old 02-18-2015, 12:26 AM
KPC67's Avatar
KPC67 KPC67 is offline
100% class!
Kevin Carter
Old 02-18-2015, 01:42 AM
Track Junky's Avatar
Great work Scotty!! Looking clean.
Gaetano Cosentino
Old 02-18-2015, 02:11 PM
I've stated before about guys should bleed their brakes on these cars completely once a year because brake fluid is "hygroscopic" meaning - it absorb moisture.... Obviously the moisture in the fluid did a nice job on the stainless pistons!! Thus proof of what I've said in the past.
Really nice job you're doing mister! I hope it's a noticeable improvement when you're all done!
Old 02-18-2015, 06:01 PM
Good as new!
Old 02-18-2015, 09:48 PM
Sieg's Avatar
good job, Scott!
Originally Posted by KPC67 View Post
100% class!
Good as new!
Thanks Gents!
