Old 02-19-2015, 06:43 PM
carbuff's Avatar
carbuff carbuff is offline
Originally Posted by 71RS/SS396 View Post
We use the front port and Iirc we use a -10 line but had to turn down the points of the wrench flats on the fitting as it can interfere with some accessory drives. I reinstall the factory plug when finished.
Tim,
Do you have any problem using this port with the oil going into pan instead of pressurizing the rest of the system? Or I wonder if your dry sump would act differently in this sense vs. my wet sump pump?
Old 02-20-2015, 02:03 AM
71RS/SS396's Avatar
Tim,
I pull the belt and use a drill to prime mine, plus I have a RHS block that has priority main oiling so it's a different kettle of fish. On stock blocks the lifter galley gets the oil first. I pull the oil plug on the pan and prime it until I get a good flow of oil out of the pan, I do all this on a dyno stand so it may not be so easy with it in the car.
Old 02-20-2015, 08:01 AM
Panteracer's Avatar
Default Bad Dyno day
I mounted mine just behind me on the tunnel in the car
Shutoff valve is right next to my seat.. I recently wrapped
the oil line with header heat wrap to help keep things cooler
but never really sensed any heat
Bob
Old 02-20-2015, 08:05 AM
Bob
Oil is NOT flowing into and out of this system.... it's only a in / out if it's needed - otherwise the oil is static. Only time it might heat up is if your car is needing the pressure during an event a few times (then something bad is going on!).
