Originally Posted by Flash68
Very cool Lance. Who says playing with carbs can't be "techie"?
I have not ran mine yet but my initial program is ready to test out after chatting with a couple of the MSD techs.
Assuming... you are running about 34 total, that would be the equivalent of running 24 "initial", 10 "mechanical" advance, and an extra 10 "start retard". Not bad. Good performance strategy, and easier to start.
I know some folks that will weld slots in the distributor to be able to limit the mechanical to only 10 so they can run more initial. This makes it pretty easy doesn't it.
Do you have a MAP? Brave enough to try some "vacuum" advance?
