Old 03-14-2015, 01:34 PM
badazz81z28 badazz81z28 is offline
For any future Inquires, the Speed Tech 67-69 adjustable Camaro crossmember as well as the Bowler Transmission crossmember do not fit. They physically bolt to the frame, just not enough set-back.
Old 03-16-2015, 10:10 AM
Blake Foster's Avatar
how could there be not enough set back? the AST has 4" of adjustment and works on the factory frame?
it should fit up in the floor recess on the body which corresponds to the trans location??? I do get that it is tight to the floor due to DSE raising the sub frame mount but the set back should be the same???
you have obviously tried it so I am not questioning that just questioning it?
Blake Foster
www.speedtechperformance.com
Old 03-16-2015, 06:45 PM
Beyond me, what boggles me is why it has so much forward adjustment. If it's for a t56, you would never need to push it that much forward.
Old 03-16-2015, 07:17 PM
Is that what is not fitting?
Loosen all the bolts to the mounts, crossmember to the frame
Then start all the bolts, then tighten them.
Old 03-16-2015, 07:23 PM
Not exactly, the crossmember' forward bolt hole is put in the center hole on the frame. I would need to drill holes in the frame, not quite ready for that.
Old 03-16-2015, 07:44 PM
Sieg's Avatar
Sieg Sieg is offline
Did this crossmember fit?
Old 03-16-2015, 07:46 PM
Super close, closer than the ATS. I'm working with Bowler transmission to work that one.
If anything I'd redrill the holes you need in those ATS plates that you have. 1 hole on each side?
Old 03-16-2015, 07:58 PM
Sieg's Avatar
Are the frame plates identical?
Could they be swapped/reversed for a gain?
Old 03-16-2015, 05:16 PM
It would really help if you gave way better information in your posts. Like DID YOU HAPPEN TO PURCHASE SET BACK MOUNTS for the motor?? And then did you expect a standard transmission crossmember to work with that?
