Originally Posted by GregWeld
Are you pushing? Or pulling? Pushing. I was having a little trouble with the curvature of the pipe as I went around. I should have stayed more on the top side of the pipe and made shorter runs before rotating the pipe
Note the difference in the spatter with the lower amperage setting. Now I'd slow the WFS just a tiny bit. WFS is something that comes with practice and lots of time behind the wheel. Don't slow it very much -- so if you were looking at numbers and you were on 18 drop to 17 - give that a try. Will do. I've noticed the WFS adjustment seems to be fairly sensitive. I was moving a lot faster than I prefer but that could be simply my inexperience with thinner material
Does your welding sound like it's SIZZLING? Smooth sizzle - steady.Yes
The old rule of welding -- you drag for slag... meaning if you're using some fill that give you slag - then you drag.... Typical MIG is done with the push method -- but that changes depending on what you're welding and position etc. Sometimes you can't push and you have to drag.
Your torch angle should be dang near vertical (right over the joint) with it angled back 5 or 10* so you can see the fill and the puddle.
Those beads look better!
Thanks Greg!
