Old 03-20-2015, 08:34 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Originally Posted by Build-It-Break-it View Post
Have you came up with a price yet for just the adapters And seal?
Not yet, I am machining a few sets next week and once machine time is determined,,,, I can put a cost to them. I do however expect the pricing to be similar as the "weld-on" kits I sell since they are very similar, and as you may or may not know those are $900.00 a set.
Additionally, the basic kit for this "bolt-on" setup will include the axle seal and ARP hardware. Appreciate your interest! Thanks!!
Originally Posted by Rod P View Post
HOLY CRAP! thats awesome....totally want
Thanks Rod, I am VERY proud of this set-up! Would love to see you beating on a set of these soon! Let me know
Originally Posted by efs69 View Post
Stay tuned for newly machined sets
Originally Posted by 130fe View Post
Stupid question- does this make a conventional rear with torino ends into a semi-floater? Curious on pricing as well. Any info would be appreciated.
I do not think any questions are stupid and believe that is how we all learn. To answer your question, a conventional rear with "torino ends" IS considered a semi-floater. This set-up would fall closer into the full floater category.
In a nutshell, with a semi-float axle, the axle shaft both carries the weight of the vehicle and transmits torque which directly relates to the failure of bearings, seals, and ultimately piston knockback.
With a full-float axle, the weight of vehicle is supported by the axle housing-more specifically and in this situation, the C6/7 Hub/Bearing that is attached/bolted to the end of the axle tube. Torque is now transmitted by the axle shaft that carries literally no weight since the Hub/Bearing Unit supports the vehicles weight now...
Old 03-21-2015, 08:00 AM
Yes, with the floating axles it should. I've run a similar weld on style flange and it absolutely has no knock back.
That implies that you actually went into a corner hard enough to move the rotor and push the pads back..... Just sayin'.... Hahahahahahahaha
Old 03-24-2015, 12:38 PM
Jr's Avatar
Jr Jr is offline
Great idea. Yes, I'm very interested.
Old 03-25-2015, 06:22 AM
Thank you Jr. I appreciate you posting up your interest.
Keep an eye on this thread for more info!
Old 03-25-2015, 10:07 AM
Payton King's Avatar
Great idea! So simple, but you are the first. Brilliant really, for the person making the upgrade with additional room or before they order wheels.
Old 03-25-2015, 12:20 PM
crazycarl's Avatar
crazycarl crazycarl is offline
Originally Posted by JSM View Post
...I do however expect the pricing to be similar as the "weld-on" kits I sell since they are very similar, and as you may or may not know those are $900.00 a set.
Does the weld-on kit for $900 include axles and the unit bearing? Gotta link to your website somewhere? There are no details in your signature or your user profile. I looked through your posts and saw a bunch of GMR stuff but when I called GMR they said you don't work for them.
I'm probably just screwing with you, so please don't take it personal.
Old 03-25-2015, 07:05 PM
Thanks Payton! Now what do I owe ya for saying that
Old 04-04-2015, 11:29 AM
4mul8ion's Avatar
4mul8ion 4mul8ion is offline
Hope this helps. These ends were from Dutchman.
Old 04-04-2015, 04:06 PM
4mul8ion's Avatar
Here's the Dutchman outer shape.
Old 04-16-2015, 11:57 AM
efs69's Avatar
efs69 efs69 is offline
Jay,
Here are some pictures of my Moser set up. It does have the inner seal as well. Hope these shots help.
